Question about Car Audio & Video
Okay, so how do i get the front door passenger side panel off of my 1995 murcury grand marque. i told you i could do it, but i'd like some expertise advise. john
  • 17,970 Answers
Check this procedure for 1992-98 Vehicles
  1. Disconnect the negative battery cable.
  2. If removing the driver's door panel, remove the nut from the outside rearview mirror control switch.
  3. Remove the window regulator switch housing by gently prying up, starting at the front.
(see Figures 3, 4 and 5 - Click over pic for zoom)
Fig. 3: Front door panel-1992-98 vehicles
Fig. 4: Rear door panel-1992-98 vehicles
Fig. 5: Remove the window regulator switch housing by gently prying up, starting at the front
  1. Detach all connectors from the switch housing.
  2. Remove the door inside handle cup.
  3. Remove the push pin from the door trim panel upper front extension and remove the screw.
  4. Remove the lower self-tapping screw retaining the door trim panel to the door inner panel.
(see Figures 6, 7 and 8 )
Fig. 6: Detach the switch housing electrical connector and remove the housing okay, so how do i - 38a6bf4.jpgbr /> 38a6bf4.jpg
Fig. 7: Remove the door inside handle cup
Fig. 8: Remove the screws from the door panel in the front and on the upper extension
  1. On Grand Marquis, pry up the screw covers from the door pull handle and remove the screws and handle.
  2. Lift the door panel upward and snap out the panel.
(see Figokay, so how do i - ef0117c.jpg10 )
Fig. 9: There are also retainokay, so how do i - a3b7184.jpglocated in the map pocket as well as ...
Fig. 10: ... along the bottom edge of the door panel
  1. Disconnect the necessary wire harnesses and remove the panel.
To install:
  1. Connect the wire harnesses to the door panel, as necessary.
  2. Install the door panel by pushing in and down until it snaps into place.
  3. Install all self-tapping screws retaining the door trim panel to the door inner panel.
  4. On Grand Marquis, install the door pull handle, tighten the screws and install the screw covers.
  5. Install the push pin covering screw on the panel upper front extension.
  6. Install the inside door handle cup.
  7. Install the window regulator switch housing and install the nut on the outside rearview mirror control switch, if removed.
  8. Connect the negative battery cable.
(see Figures 11, 12, 13 and 14 )
Fig. 11: Lift the door panel upward and snap out the panel to remove it from the door
Fig. 12: Rotate the door marker lamp bulb and remove it from the door panel
Fig. 13: Detach the connectors for the trunklid and fuel door release switches
Fig. 14: Slide the relay connector off of the door panel and remove the door panel from the vehicle
Hope this helps.
Posted on Aug 26, 2010
Key will not turn in passenger side door lock, 1995 Grand Marquis
when dealing with locks the specialist to seek advice from is a locksmith not a mechanic
yes it probably will fit and if you use the services of a locksmith ( who can provide the barrel and have it set to the existing key
Jul 31, 2015 | 1995 Mercury Grand Marquis
Where is the fuse box located?
Open the passenger side front door...the inside fuse panel is under the pop off cover on the right side of the dashboard...(you cannot access this unless the passenger door is open...also try the internet under search engine..."Jeep Grand Cherokee Forum"...Hope this helps.
Feb 02, 2011 | 1994 Jeep Grand Cherokee
Can I use front window motor for back window?
This is going to sound wrong, but I have been told the window motors will match but not on the same side. For some reason they are crisscrossed. The drivers front matches the passengers side rear motor. The passengers front matches the drivers rear motor.
So basically there are only 2 part numbers for the 4 motors. I was lucky enough to find the exact motor in the identical door I was having to repair on my 1994 Crown Vic. I was thinking to use the front passenger motor for the front drivers motor and thats when I learned about window motors.
Aug 28, 2010 | 1995 Mercury Grand Marquis
Where is the fuse panel for my 1995 Jeep Grand Cherokee?
You have one under the hood near the battery and one on the passenger side interior kick panel (or near it, visible with the door open)
Jun 11, 2010 | 1995 Jeep Grand Cherokee
Factory Alarm System is killing the battery and I want to disable it because I don't have the original key with the chip to shut off alarm.
Okay so here's what you do...take driver side door panel off and look for a purple and yellow wire in the wire bundle. Cut this wire and using a ring connector, strip and crimp connector on end of wire running from the front of the door (i.e. hinge side of door). Using a self tapping screw, screw the ring connector into the metal behind the door panel....you are basically grounding the alarm system. Wrap the other end of the cut purple and yellow alarm wire with electric tape and your done. If you don't want to take the door apart you can also access the purple and yellow wire in the driver side kick panel at the black plug....you would follow the same procedure as you would for the door. Good Luck!
May 06, 2010 | 1995 Jeep Grand Cherokee
How to remove a door panel on a 1995 pontiac grand
I have info on a 96 power door glass.....should be very simular. the triangle piece at the top front is just clipped on, the plastic piece around the opener handle is just clipped on. in the pull handle there are two screws, and the plastic piece just pops up. under the red reflector the is a screw. There is a "U" clip behind your window crank, remove this clip and the crank will pull straight out. (use a screw driver to open the gap between the crank and the door panel, to see the clip, Use a hook tool too remove the clip...you can also use a cloth or panty-hose in the gap and turn the crank, the cloth will grab the edge of the clip and pop it off)
after removing all the clips and screws the door panel is held on with plastic plugs, just pull the panel sraight out toward youself.
hope this helps.
Apr 01, 2010 | 1995 Pontiac Grand Am
Windows will not go up or down jeep grand cherokee 1995 checked fuse on passenger side and is ok
remove door panel inside.
check that u have 12 volts with test light at window motor plug.
check the the regulator/pulley system cable is not broke.
Oct 23, 2009 | 1995 Jeep Grand Cherokee
1997 jeep grand cherokee front windows not working, rear working fine
open door check wires in rubber boot on both sides i just had the same problem. it was 1 bad wire on each side
May 21, 2009 | 1997 Jeep Grand Cherokee
The front drivers door window has fallen off its track and fallen inside the door panel. My car is a 1995 mercury marque. I'm trying to take off the door panel. PS I'm a female so this is new for me . It's...
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Dec 12, 2008 | 1995 Mercury Grand Marquis
Removing inside door panel 1998 safari van
rear hatch door on 2000 gmc safari will not unlock-how can I open it?
Nov 22, 2008 | 1998 GMC Safari
Car Audio & Video Logo
190 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
