Question about Casablanca Fan W-62 LCD Remote Control
Fan has worked fine for 1 year all of a sudden, fan does not work with remote. If I turn on the outlet switch fan works at high speed only, without any control from the remote
  • 8,457 Answers
Take the remote aparts,clean the PCB with some Q tips with rubbbing alchahol.Check the back of the rubbers buttons back back films.If clean the PCB with some rubbing alchahol and the back films of the buttons are good.After the process,the remote should work.Not,than the reomote CPU is dead and it useless.
Posted on Aug 26, 2010
Why doesn't ceiling fan reverse?
Putting the fan in reverse is done by mechanically reversing the leads powering the motor. All the wall switch does is supply the power and the fan circuits take care of the speeds and direction.
Your problem is with the fan reverse control and/or electronics.
Sep 08, 2015 | Dryers
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
"Ball Ceiling Fan" - hardwired wall switch only turns on or off, no speed control or light control, stuck on "high" and light "on" when switch is in "on" position.
The most likely cause (and the one I've always encountered) is the switch/controller nit wears out from electrical arcing that burns the contacts or temperature kills electronics on "soft" speed controllers
Mar 03, 2013 | Modern Fan company ball ceiling fan
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan and light suddenly wont work.
May be the receiver Call Hampton Bay @ 18005533199 have your UPC number ready
Oct 27, 2009 | Hunter Dryers
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Casablanca Fan W-62 LCD Remote Control Logo
245 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
