Question about Kenmore Washing Machines
Model # 22712100 ser # 185642 washer will not go in to spin cycle
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer will not go into
If the washer fills normally, but stops when it gets to the spin cycle, this could be a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. The lid switch is located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. If the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 (part number 3949238) and is fairly simple to replace. You can locate it at searspartsdirect.com. Just type in your model number in the "Searched by Model" block and you can find it under the "Top and Cabinet" heading as Item number 11. The lid strike costs about $11 (part number 350733), and can be found under the same heading as item number 20. If you go to my profile and click on "Tips and Tricks" I have a posting listed on how to replace a lid switch.
If your washer fills and simply does not agitate or spin, and a loud rattling noise can be heard, you may have a defective motor coupling (part number 285753A). It can be located under the "Brake/Clutch/Gearcase/Motor/Pump" heading as item number 13. I also have a posting explaining how to replace a motor coupling. A new coupling costs about $15 and is also very easy to replace. NOTE: The washer will still drain if the motor coupling is bad.
If the diagnosis is incorrect, please post back with comments and describe your symptoms a little more in depth, so I can give you a more accurate solution. I hope you find this information helpful.
Posted on May 06, 2008
  • 18 Answers
SOURCE: My Kenmore Top Load Washer 22712100 will not spin
It sounds like your drive belt is excessively worn. Note that some machines will (barely) agitate with a worn belt, but when subjected to the demands of a spin cycle, a worn belt will slip indefinitely.
Posted on Oct 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Water will not stop flowing and wash cycle will not run
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
heatman101
  • 43501 Answers
SOURCE: kenmore washer MOD 110.24422300 SER
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 20, 2010
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
My Kenmore Top Load Washer 22712100 will not spin clothes. What is the problem?
Oct 05, 2009 | Kenmore Washing Machines
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Have kenmore 70 series washer model #20702991 ser #1069231 type 111 will not drain. It starts the cycle by agitating then stops and will not go to drain cycle. switch on top lid does not ckick, tried...
The lid switch must close for the washer to spin. I've seen a lot of these break where it's mounted to the top. You may still be able to reach under the top to grab the switch to close it and get it to drain. You'll almost certainly need to replace the lid switch.
Jul 21, 2008 | Washing Machines
Washer will not go into spin cycle model # 22712100
May 06, 2008 | Washing Machines
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
