Question about Mitsubishi WD-73833 73" HDTV
My TV picture is starting to have a noticable flicker. Could be the lamps going out? If so how are they changed? Is this something I can do?
  • 734 Answers
Take the TV apart. Have the lamps ready and use gloves to put the lamps in place. Never touch the lamps with bare hands because sodium will degrade the quartz lamps.
Posted on Aug 26, 2010
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Have a wd60638 changed the lamp because old one busted now the TV works fine for about 3-5 minutes starts to hum and a clicking sound and pictures begins to flicker with colors going in and out
normally no bulb will bust ever unless you have oil on the lamp. sooo , it got too hot then. even if the fans turning its not putting out.
check the exhaust it should blow a lot of air past the lamp.
Oct 19, 2014 | Mitsubishi Televison & Video
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Ballast or Lamp?
Its not the lamp or the ballast board. In either case, you would lose picture (going blank or black) and sound would soon follow then the LEDs in front would blink if at all.
Odds are its either the DMD board or the digital board.
michtech
Feb 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Green or blue vertical lines on my WD52525
it is not the lamp. the DM board is causing this problem. if the DM is going bad the FMT is not far behind. it will cost you $250.00 plus shipping one way. see www.tv-techs.com
Jan 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
Jan 30, 2008 | Sharp 65DR650 65" Rear Projection...
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Mitsubishi WD-73833 73" HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
