Question about Garmin GPS
Gamin turn on but does not go to main screen stalled
  • 15,935 Answers
Perform a master reset.
CLICK HERE to see the procedure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
Gamin nuvi 1450 wonot start and the gamin express cannot recognize it
Your Nuvi has to boot past the Garmin logo to the main screen before it can be recognized by your PC. Is the unit dead? The Nuvi 14xx series is well known for its problem with the rear USB port coming loose. This will prevent the unit from receiving power from the external charger and will prevent the battery from being charged. If the unit goes into a boot-up loop, displaying the Garmin logo then shuts down, this is often caused by corrupted files, such as a map or bad firmware update. See these two links for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Nov 01, 2014 | Garmin nuvi GPS
My gps gamin 660 is not charging. Do I need a new battery or it is an other fault?I have just updated/ download new map 2012.12
Check to make sure that you have a yellow lightning bolt over the battery icon on the main screen. If not, your charger is bad. If you do, then the battery is probably bad. Please see these links for more info:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jun 11, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin screen black, won't turn on, how do I reset?
The reset button is situated at the bottom left back of your unit. You need to peel the serial number from the left so that you can see the reset button. Gd Luck..
Jul 02, 2010 | Garmin nuvi 205 GPS Receiver
My mains charger exploded and now 205 does not charge also no comms. Unit worked normally till battery went flat. When plugged into PC usb, Unit gets warm in area around mem card but does not charge.Any...
This is a new set of symptoms to me, but whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205W GPS Receiver
My garmin nuvi 205 won't turn on
Whenever these devices start acting up, such as not turning on or not loading past the Garmin welcome screen, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 will not turn on
Whenever these devices start acting up, like not turning on anymore or getting stuck at the Garmin welcome screen, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 03, 2009 | Garmin nuvi 205 GPS Receiver
I am charging my Gamin Edge 305 and can barely see the LCD screen
  1. Power the unit on.
  2. Press the mode button to access the Main Menu.
  3. Select Setting > System > Display > Contrast.
  4. Now press the enter button and continue pressing the arrows up or down to change the contrast.
Jul 04, 2009 | Garmin Edge 305 GPS Receiver
I can't turn my Gamin Nuvi 260W off
Push and release the spring loaded on button on top of the 260 to turn off.
Dec 13, 2008 | Garmin nuvi 260W GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
