Question about Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDE6400AY dryer will not shut off by itself and the timer does not advance in the cycle. I have replaced the timer twice so I know it's not the timer. Also the dryer doesn't stop when door is opened.
  • 15,935 Answers
The door switch is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
Maytag atlantis MDE6400AY timer works but dryer doesn't come on
First thin I would try is to check your thermal fuse for continuity with a ohm meter with the wires removed from the fuse and the dryer unplugged. Its located on the tunnel that in cases the heating element.
Here is the part in case you find it bad.
Oct 31, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Hi i need the part number for a maytag atlantis dryer timer
part number for timer is AP4043083 , if you also need the timer clutch that number is AP4042974 both thru appliancepartspros for about $85.00 each
Mar 05, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
I have a ldg382 gas dryer. The dryer runs and heats a little, and the timer will not advance, stays in same position.
disconnect vent tube, run dryer as it shall work now. I would guess restricted vent tube. Good Luck Tim
Jan 16, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
What is the part number for the timer?
The timer for Maytag Atlantis MDE6400AY is part number 33002855. Specify the model number of the dryer if it is different from the given above.
Apr 26, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
128 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
