Question about GE 25932 Cordless Phone
5.8 GHz GE CORDLESS PHONE is still flashing after being on the charge base for 12 hours
  • 32 Answers
The battery is bad and needs to be replace.
the battery has three poles: one ground and two plus
the middle connector is wired with a small thermistor or diode to the plus connector. and this part is bad (open contact), so it will not signal to the phone print board to start the charging proces.
Posted on Aug 26, 2010
  • bert bert Aug 26, 2010
    the battery is bad and needs to be replace.
For ge 25942ee4 5.8 ghz - i can't locate instructions. need to know how to correct the day and time on main base phone.
1. Make sure the answering system is ON.
2. Press fash/answerer/call waiting button on the handset to enter answerer remote
mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confrm the setting.
Sep 30, 2009 | GE 25952EE1 Cordless Phone
GE 2.4 GHz cordless telephone problem
Hi there, maybe I can help;
Is the phone base plugged into an switched outlet and is the switch off?
Let me know if I helped
Jan 06, 2009 | GE 21008GE2 Dual-Handset Cordless...
System keeps flashing with CL
Program the clock. There are a some buttons on the back of the base unit that sets day of the week, hour, and minute.
Dec 18, 2008 | General Electric 28031EE3 5.8 GHz 1-Line...
Battery holds a charge for a short time only
These phones are known for the contacts not transferring adequate voltage to fully charge the phone.
Oct 23, 2008 | GE 26928GE1 Cordless Phone
Need instructions to make cordless twin set work
If you had a power failure the memory may have been affected. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may need to register the handset to the base by following the instructions in the user's manual
Sep 12, 2008 | GE 25952 Cordless Phone
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Cordless phone remote unit
The CL light flashes all the time and it wont let me program it>
Mar 18, 2008 | GE 25942GE2 Cordless Phone System
GE 5.8 ghz cordless model 25922
as with all devices which return to base for charging, the life of the re-chargeable batteries is shortened if it is constantly trickle-charged, so as with a moble phone, it is good to sometimes let it run down completely and re-charge as the battery charge will last longer, batteries are like muscles, they need excercise.
Jan 09, 2008 | Uniden Cordless Phone
GE 25836EE1-B 5.8 Ghz cordless
@Guest
Put the second handset in the main base charge cradle for 20 seconds. It should then turn to READY status.
Dec 21, 2007 | GE 25942GE2 Cordless Phone System
My Phone Won't Recieve A Signal?
I Have exactly the same problem. maybe someone found a workaround for this issue? Thank you
Jul 21, 2007 | GE 26939GE2 Cordless Phone
GE 25932 Cordless Phone Logo
82 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
