Question about Garden
My power washer will start up but cuts right back off. I bought irt from a guy and it seemed to have a lot of oil in it
    Problem Solver:
  • 18 Answers
Your unit probably seat for long time and gasoline leak in crankcase you need to drain oil and put fresh oil then try again
Posted on Aug 27, 2010
Motor fires up fine runs slightly rough for about 10 seconds then smooths out for about 5 seconds and cuts off. Will start right back up after about 5 seconds and does the same thing. I have drained the...
Previous owner had way overfilled crankcase oil. Oil had gotten into carb and clogged air filter. Drained oil to correct level. Ran engine but kept cutting off-see above. Took off carb cover cleaned housing and ran without air filter-ran fine. Unsuccessfully tried to clean air filter with gas-did not work. Apparently, the engine could run just long enough to exhaust the air in the old filter and cut off which is why it would start back up after a few seconds. Bought new air filter-whole thing-about $15 at Carquest. Put in some carb cleaner and installed the new filter and it runs perfectly.
Jun 10, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Valves in 2000 ford ranger, 4.0, v-6, are ticking loud and want to know what i can/should do. has a lot of miles but runs great. no oil burnimg between changes or leaks or smoking, it simply is loud t
Change the lifters,and the push rods,other than that leave alone,There very common noise,even if new it will make noise again,if you decide to fix it, it make it a hobby you will always be doing it.
Nov 12, 2012 | Oldsmobile Cutlass Ciera Cars & Trucks
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
Apr 11, 2009 | Dewalt DPD3100 Gas Pressure Washer
Husqvarna 345 power loss and vibrates
Replace the bar. Your bar has gone bad and that is why you are losing power. Bars are made by the chain saws to be completely oiled at all times. When the bar does not get oil the bar will start to warp and that is what will cause you lack of power when trying to due a top cut
Feb 14, 2009 | Husqvarna Forest & Garden No.967012396 345...
Wire is on the botom of the motor and i dont konw what is is
Hi
Remove the fan housing.There you can see the coil.Follow those wires(2) towards the on/off switch.Replace that wire with a new one and start the engine.
best regards savumihai71
Feb 12, 2009 | Homelite ZR10926 16 Chain Saw
My campbell and housfield 60 gal wont run.. help
10 AMP CIRCUIT SOUNDS WEAK. WIRE MAY BE TOO SMALL. ARE YOU SURE ITS NOT WIRED FOR 220 VOLTS AND YOUR RUNNING IT ON 110. START CAPACITOR COULD BE BAD BUT TYPICALLY WOULD LEAK OIL-LIKE FLUID IF IT WAS DAMAGED. CUTTING OFF AND ON CONTINOUSLY COULD BE THE PRESSURE SWITCH IS DAMAGED. SOUNDS MORE LIKE WRONG VOLTAGE. THERE ISNT A LOW OIL PROTECTION DEVICE.?
Feb 04, 2009 | Campbell Hausfeld 26 - Gallon Air...
Mind of its own
THE ONLY RESET IS TO UNPLUG IT FOR 15 MIN. SOUNDS LIKE MAIN CONTROL BOARD BAD
Oct 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
