Question about Brother HL-4070CDW Printer
HL Brother 4070 CDW printer- printer indicates paper jam in the back of the printer. There appears to be a roller with printer images on it but it's bittle paper (also as if burned) and I can't remove it. What should I do? This is a church office and this printer is used constantly.
  • 3,083 Answers
Printers are never easy or fun to work on. If you have someone handy in the Church, you might impore them to help. If you can't clear a paper jam from the front, the unit will have to be taken apart.
You might have to have a computer repair shop assist you, but have the preacher summons the members in hopes of finding some free help first. Here is an excerpt from safemanuals.com about paper requirements:
Recommended paper Europe Plain paper Xerox Premier 80 g/m2 Xerox Business 80 g/m2 Recycled paper Labels Envelope Xerox Recycled Supreme 80 g/m2 Avery laser label L7163 Antalis River series (DL) USA Xerox 4200DP 20 lb Hammermill Laser Print (24 lb=90g/m2) N/A Avery laser labels white #5160 Columbian #138 (COM10) 2 Before you buy a lot of paper, test a small quantity to make sure that the paper is suitable. Use paper that is made for plain-paper copying. Use paper that is 75 to 90 g/m2 (20 to 24 lb). Use neutral paper. Do not use acidic or alkaline paper. Use long-grain paper. Use paper with a moisture content of approximately 5%. This printer can use recycled paper that meets DIN 19309 specifications. CAUTION DO NOT use ink jet paper because it may cause a paper jam or damage your printer. Note If you use paper that is not recommended, a paper jam or misfeed may occur in the printer. (To help you choose which paper to use with this printer, see Important information for choosing your paper on page 177.) 7 Printing Methods Types of envelopes Most envelopes will be suitable for your printer. However, some envelopes may have feed and print quality problems due to the way they have been made. A suitable envelope should have edges with straight, wellcreased folds and the leading edge should not be thicker than two pieces of paper. The envelope should lie flat and not be of baggy or flimsy construction. You should buy quality envelopes from a supplier who understands that you will be using the envelopes in a laser printer. Before you print a lot of envelopes, test one to make sure that the print results are what you want. Brother does not recommend a particular envelope because envelope manufacturers may change the envelope specifications. You are responsible for the quality and performance of the envelopes you use. Do not use damaged, curled, wrinkled, irregularly shaped, extremely shiny or textured envelopes. Do not use envelopes with clasps, snaps, tie strings, self-adhesive components, windows, holes, cutouts or perforations. Do not use envelopes that are of a baggy construction, not sharply creased, embossed (have raised writing on them) or pre-printed on the inside. Do not use envelopes that were previously printed by a laser printer. Do not use envelopes that cannot be arranged when put in a pile. Do not use envelopes that are made of paper that weighs more than the paper weight specifications for the printer. 2 2 Do not use envelopes that have been badly made, with edges that are not straight or consistently square. If you use any of the types of envelopes listed above, they may damage your printer. This damage is not covered under any Brother warranty or service agreement. Note · Do not put different types of paper in the paper tray at the same time because it may cause paper jams or misfeeds. · Do not print envelopes using duplex printing. · You must choose the same paper size from your application as the paper in the tray.
In case you don't have a manual for this printer, you can download one here:
http://www.retrevo.com/support/Brother-HL-4070CDW-Printers-manual/id/3258ci853/t/2/
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 26, 2010
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
Black line on right side of paper everytime I print brother 4070
I think you hav low or bat toner cartridge or dirty feed rollers. If a replacement cartridge doen not fix your problem then your printer needs cleaning/servicing.
Aug 10, 2011 | Brother HL-4070CDW Printer
My brother HL 4070 CDW printer says to change the belt. What do I do?
Ther is a picture in the manual that will show you. It won't insert on here. Send me and email joediaz911@gmail.com, I will send yout the PDF.
Feb 21, 2011 | Office Equipment & Supplies
Paper red light is blinking and it won't print but there's paper in the printer. I had to pull out 2 pieces of stuck paper earlier.
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 29, 2010 | Brother HL-2040 Laser Printer
We have a Brother HL 4070 CDW printer and it's leaving black smudges down every printed page. We have tried vacuming it out, but that did not help the smudges. Any ideas?
Hi there !
this is a commun problem for all the printers, you should clean you printer's inside !
for that printer you habe to check all the way where the paper moves.
Aug 20, 2010 | Brother Office Equipment & Supplies
Brother HL-1670n failing to feed paper.
I am facing problem for my "Brother HL- 1670N" printer with error E52.
Please help me out!
rj_rrohanjag@yahoo.co.in
Nov 04, 2009 | Brother HL 1670N Laser Printer
Will not make connection to wireless brother hl 4070 cdw printer
You might not be on the wireless network or the printer might not be on the wireless netowrk. try connecting to it via a usb cable and see if that works. if so try reconfiguring the settings on it for your wireless network than try again. Also if you have the disk the printer came with you can uninstall the printer put back in the disk, reinstall the printer and it might do all that I am saying automatically.
Sep 12, 2009 | Brother HL-4070CDW Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Reset page counter
Try to unplug your printer and leave it for 1 to 2 hours.
Feb 27, 2008 | Dell 1710n Laser Printer
Brother HL-4070CDW Printer Logo
395 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
