Question about Fisher and Paykel GWL11 Top Load Washer
We can not turn on the washer and their is an odd burning odor
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now I need you to look underneath the machine to the front right and you should see a red or black fan.This is your pump.On these models of machines if your pump is faulty then it will not power up.The other reason it does not turn on is your motor controller is faulty.Now once you are looking at the pump see if the odor is coming from the pump or check to see if it is corroded or leaking.Make sure you turn the power off before you look at the pump.Please reply and let me know what the pumps condition is and I can help you further.Looking forward to your reply.
Posted on Aug 27, 2010
LG WM4070H front load direct drive washing machine occasionally emitting burning rubber smell.
Sanitary cycle uses calrod heating element inside of washer to heat water. I suspect that is where smell is coming from. If you infrequently use sanitary, and if you use fabric softener and/or liquid detergent, then a built up on the calrod unit can happen. When used, the buildup can produce odors as you describe.
Apr 09, 2017 | LG Washing Machines
How do I remove odor from duet front load washer?
Assuming the odor is not a burning rubber smell or some other type of odor caused by a mechanical malfunction:
Remove the bottom of the washer (three screws I believe and above the drawer if you have one) and then open up the drain pump catch and clean it. You may want to put down some towels or even a bowl to catch water that will spill out. There are videos on how to clean this on youtube "Whirlpool Duet Water Pump Drain Catch". I believe this will solve the problem.
Oct 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a maytag model# mav2755aww, I have a burn smell when it's in the spin cycle. yes it is spinning the water is draining ?
Burning odor may be coming from a overheated motor under a heavy spin load.
Before going any further;
1.Make sure the circuit breaker for the machine is working properly and know its location.
2.Have a working fire extinguisher nearby.
3.If a electrical/motor fire starts, you need to turn off breaker power to the washer..Then use the extinguisher to put out any fire.
Try spinning the basket empty and see if the odor still persists if so, you need a new motor ..
If not, you have to think about the weight of the washload that the spin cycle must handle..
If a light load causes the same odor, stop using the machine until you replace the motor and check the transmission for any problems.
Oct 02, 2014 | Washing Machines
I have a 2100 Electrolux cannister vac. I have just noticed an odd odor (similar to burning) and the protection mode light went on. Can you advise of steps to take to rtrouble shoot and what might be...
The motor is probably burning out, or has. Smell the exhaust port. If the odor is especially strong, here, then that's the problem. You'll need to take the vacuum to the nearest Aerus Electrolux store for definite diagnosis and repair/replacement of parts.
http://www.aerushome.com/storelocator/index.cfm
Feb 01, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Foul water smell coming from washer after using machine.
Check the hoses to make sure there are no leaks or standing water behind. Try running a cycle or two of vinegar water and baking soda water to kill any mildew that might be in the tub.
New washers often give off an odor described as a burning match or electrical smell. This is normal and is caused by the "wearing in" of clutch shoes and the heating of new paint on the motor windings.
Older washer odors are usually caused by leaving the washer lid closed when not in use. This does not allow air to circulate and dry out the moisture remaining in tub area. The air and moisture mixture becomes stagnant and creates an odor. When washer is not in use, leaving the lid up/open for air circulation will help prevent odor.
To get rid of odors inside of washer follow the steps listed below:
  1. Fill the washer with hot water; set at regular speed & longest time.
  2. Add 3/4 cup of Calgon Clothes Detergent. (Baking soda can be substituted) .
  3. Allow washer to complete entire wash and rinse cycle.
  4. If odor lingers, repeat entire process.
Oct 18, 2009 | Washing Machines
The Kenmore Model 70 Smells Electrical Burning,
Hi..
You need to unplug the washer. Locate the source of the odor then read the instructions in the related section.You need to open the back cover, Check the parts which is spark, and become faulty, there is a short circuit, that become loose contact.
Regards
PCmania
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Burning odor then whirring sound all within one weeks time
Could be belts or some fluid on the engine( power steering fluid) if your steering feels strange.
Feb 03, 2009 | 2002 Dodge Neon
Odd odor
Yes..... that odor you smell was a component burning out on the circuit board. if you were lucking it only burned out one thing. fixable....if you have the time. actually anything is fixable it usually boils down to the cost of fixing it vs replacing the item.
Robert
Sep 26, 2008 | Grundig S350 AM/FM/SW Radio
Washing machine has burning odor
smell usually come from motor over worked, possibly under powered( check to make sure you have a110 volt, supply and not perhaps 100, possible bad start capacitor eminating small as well, its mounted either to the motor itself or on the back wall just below the water valve assy
Apr 21, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
