Question about GE 30 in. JGP326 Gas Cooktop
The cooktop is clicking continuously. I unplugged it for a few hours, but when I plugged it back it started doing the same noise. What should I do.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 30, 2010
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
All the burners are clicking
Hi there.I think what you have done is you have gotten water in & its just shorting out & causeing them to click.this should go away once it drys out.Meanwhile leave it unplugged.plug it back in every so many hour & see if it's stopped.
Jun 04, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
Ignitor sparks continuously
Hi, How long ago did you get the ignitors wet? Most cases, unplug the range for a few hours giving it time to dry out. Maybe set a fan near the range top to help dry it. This helps MOST of the time. please let me know if it helps or if I can assist you further.
Vic
Jul 04, 2009 | Cooktops
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Trouble with Kenmore Gas Cooktop
hi there,
the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
Sep 28, 2008 | Cooktops
Ignition stays constantly on, How to fix it or shut it off
its a gas cooktop it has to be plugged in somewhere op e the cabinet and unplug it. possible that the electrodes got wet and click from a false sense of continuity, after being unplugged overnight that will sometimes be enough. you also might have a bad start switch on one of hte burners causing the machine to click automatically. try unplugging over night first
Mar 11, 2008 | Maytag 30 in. CSG7000 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
GE 30 in. JGP326 Gas Cooktop Logo
261 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
