Question about Kenmore HE2 Plus Front Load Washer
How do you re-start a load of wash after you have pressed the "pause" botton?
  • 15,935 Answers
Press start or pause again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
  • elainegarth Aug 26, 2010
    I already tried that remedy and it did not work!!!!
  • blueextc3221
    blueextc3221 Aug 26, 2010
    what is the exact model # - so I can look up the manual?
    Thanks!
The water level is too low in my LG waveforce top load washer. How do I add more water?
press the pause ,,,,at ur left hand situated the water level botton,,,,,press to incress ,,the is a level indicator,,when reach to ur maximum choice then press the pause start botton again
Jan 16, 2015 | LG Washing Machines
What should i do? It continues to add time and cycles?
just press the botton of each cycle want u want,like add rinse press rinse botton and it will add rinse,press spin botton it will add spin,but for washing,cant coz already set the time,default program for wash and cannot change
Oct 31, 2013 | Samsung WA50F9A8DSP Platinum 5.0 cu. ft....
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Every time I press start the washing machine goes into pause when pressing start button
its most likely a faulty button, press start once again and it should start the cycle. usually the start and pause buttons are the same ones.
Oct 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Frond load washer Frigidare ES1
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 you need to replace door lock..
hope it helps
Aug 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Control panel
Are you sure the door is closed properly? Give it an extra push. The start/pause button could also be damaged/faulty. Try switching the machine off at the wall socket and on again.
Nov 03, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
