I dont know how to hook my dvd player to what kind of cables do i need?
  • 734 Answers
DVD players usually have video and stereo cable connections that you can connect to a TV. If your TV has only RF antenna input, then you need a RF converter($10-20) that can change video and stereo cables to RF cable.
Posted on Aug 26, 2010
Do i need a s cord for sound when hooking up dvd player to tv
  • The connection you choose depends on the kind of connections available on your TV and on your DVD player. Some manufacturers provide only one kind of connection, others two kinds, and still others all three.
  • Regular AV connections provide good video quality.
  • S-Video provides better video quality.
  • Component Video provides the best quality video next to HDMI.
  • HDMI connections are the highest quality connections If need be adapters are available, to switch from S video cable to what you want. Check the attached links,instruction and guides, Good luck.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How Do Connect My DVD Player To My TV
How to Hook Up DVD Player
Video Adapters
Mar 26, 2016 | Audio Players & Recorders
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
MY TV will not show color on the tv .I have a protron PDS2315 .I don't have the cables that came with the DVD player Does that make the deference?
Hi zapchenk,
First of all, thank you for posting your question here at Fixya.com.
The most common caused of "No color" fault when viewing movies through DVD player are :
1. Wrong TV/DVD format - If your TV is a NTSC system format and not knowingly your DVD player is set to PAL/Secam system format, then there's no color generated to your TV due to incorrect video frequency signal coming from the DVD player.
Solution : You have to sync/match the system format of the TV and DVD player. Check first the system format of the DVD player through the menu. Try to change it from PAL/Secam to NTSC.
2. Wrong hooked up - Since the problem is in video, you have to check the video hooked to your TV and DVD player. HDMI jack is the best option to avoid wrong hooked up because it come with Audio and Video in just one cable. If you are using one RCA cable to connect the video, make sure that it is hooked up to Video in of the TV and Video out of the DVD player, it is usually color yellow RCA jack. If you are using the component video hooked up, you must have 3 RCA cable for video alone. It is color coded as green(Y), blue(Pb/Cb), and red(Pr/Cr) RCA jack.
My advice is to check first the system format and then the video hooked up.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 10, 2011 | Televison & Video
I need a remote control and i need to know how to hook my cyberhome to a tv. Its a use one
you need to purchase cable wire (yellow/red & white) at least 3 feet..yellow is video red & white is audio...plug into the color jacks on tv...the remote is kind of hard this dvd model is discontinued....
May 19, 2010 | Cyberhome CH-DVD 300 DVD Player
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
Hooking up Pioneer DV 250 DVD player through Directv Satelite Receiver
i dont know what hooks up were on my tv i have rca jacks but cant seem to get it all to play , hell i dont even know what channle to put the tv on, i do have a cable box to
Sep 17, 2008 | Pioneer DV-250
Connecting Panasonic DVD to TV
What kind of cables are you using to hook up the DVD to the TV? Are they they composite, component, or S-Video? What are the connectors you're plugging both ends of the cables into labeled? Are you plugging the audio cables into the TV or directly into the sound system?
Jan 12, 2008 | Panasonic TC-32LX60 32 in. LCD Television
X-Box
You can get the RF adaptor from microsoft, but you cant connect the Xbox directly to any recording device, it is some kind of coppyright protection thing microsoft put in every game system.  you cvould also try getting a $20 video switcher from walmart if You dont want to mess around with more cables
Jan 08, 2008 | Emerson EWD2203 DVD Player/VCR
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
