Question about Rowenta DX6700 Iron
There seems to be a short in the cord that connects to the iron. This is my second Rowenta iron, and the same problem with the other one. I don't like ironing with it working only part time. First there is spray, then the power goes off, and we have water running out of the iron. when you hold the cord a certain way, it seems to connect. The iron isn't even one year old yet! Please help!
SOURCE: Rowenta Iron
go to home depot buy s single srewdriver or a multy size set.
 or wal-mart
Posted on Oct 14, 2007
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
  • 18 Answers
SOURCE: iron not staying on
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
SOURCE: wiring diagram for Rowenta DE-05
I have a DE-05 that needs a new cord and cleaning of steam discharge holes. I'll be gald to take photos and send them to you if you'll share your source for parts and method of disassembly. Contact me at, just replace the AT with @.
Chuck Jones
Posted on May 30, 2009
I plug iron red light stays lit but sole plate dont get hot
The connection to the resistance might be burned out. disassemble carully, might need soldering.
If you disassemble and don't have experience repairing an iron, take photos for each step. See some videos about iron repairing
Iron Disassembly Process
Iron Repair No Power or Short in cord wire Rowenta Master
How to repair broken iron
Iron Repairing sajid salman flv
Oct 26, 2015 | Irons
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
How to remove cord on Rowenta DZ2061
Your iron probably has tamper proof outer screws with a center pin...don't be intimidated. First, try to remove the screws with a tiny screwdriver from an eyeglass repair kit. If that doesn't work, get a Torx T-20 nutdriver attachment.
If you have to replace the cord, here's a possible supplier:
Oct 05, 2012 | Rowenta DZ2010 Iron
My rowena precision steam iron steam does not work
Solution for me:
I just bought a Rowenta Precision for $5.95 at Goodwill. I brought it home and it didn't work
I read about the cords and weird size screwdriver needed. It sounds like a lot of work. So what I did was push the electrical cord into the iron. it didn't seem to move but must have. The iron works perfectly now. Such a deal!
Mar 05, 2011 | Rowenta Precision DM580 Iron
I have a 1750 watt Rowenta Professional iron. The cord end accidentally fell into a vat of saltwater that was under the shelf where I store my iron. (The saltwater is for my marine fish tank). Now the...
The residual salt inside will be enough for the GFI to think that there is a short in the iron...
Shoet of takeing the iron completely apart and cleaning everything there is nothing you can do...
Aug 23, 2010 | Rowenta Irons
Rowenta cord repair
I would get the part for your specific Rowenta iron from the Rowenta service center for this half of the US:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is:
or tech service:
Then, if you do not want to send it there, go to local Applicance servicer you trust to have cord replaced locally if you prefer. I know it seems picky, but consumer products are UL approved, and I would not want loved ones working with a product I did not have serviced properly.
May 25, 2010 | Rowenta DG-980 Iron
Will not turn on
There is some misconduct wire, loose or disconnected. Have it serviced, if possible replace the cable :)
Apr 04, 2010 | Rowenta Power Duo Iron
Rowenta Iron-Professional Luxe The power cord seems to short out when you move iron. You can wiggle it next to the movable ball and it clicks on and off. The two screw heads on bottom appear to be special...
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Oct 22, 2009 | Rowenta Irons
This is probably caused by a connection inside the iron which is arcing. Should be disassembled and all connections inspected for heat damage. Repair connections as appropriate.
Aug 20, 2009 | Rowenta DG-920 Iron
Rowenta dx6700
Sep 23, 2007 | Rowenta DX6700 Iron
Rowenta DX6700 Iron Logo
173 people viewed this question
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
