Question about GPS
I have a Medion GPS. On the back label it writes: x11-15297. My software is broken. Where can I download it?
How to unlock and how to get a user manual.
First of all, you need to download and install the Medion GoPal Assistant on your PC:
  • Launch the software and connect the Medion navigation device to your PC.
  • The device is now recognized by Medion GoPal Assistant.
  • Click to on Start > Search to check for available updates.
  • If an update is available, it is automatically downloaded and installed by Medion GoPal Assistant.
Mar 01, 2016 | Medion Go Pal P4410 GPS Receiver
My p4425 will not boot up. just a blue start up screen.
If your medion gopal p4425 will not boot up, then there is a problem somewhere. The problem is minor as it is that, a file that supports its booting is missing.
Solution,
  1. Reset your gps receiver by pressing down the reset button for about 5 seconds or holding the power on/off button for about 15 seconds.
  2. The gps receiver will restart and that way boot normally.
If reseting does not solve the problem, then the solution is for you to format the gps and restore the gps software on it. To do that:
  1. Connect your gps receiver to your computer using a USB cable,
  2. Select the computer from your start menu,
  3. Right click on the gps receiver from the computer age,
  4. Select format drive,
  5. Do not quick format, format normally,
  6. Then go to your gps receivers website and download its software,
  7. Then transfer the software onto the gps receiver,
  8. You can download the latest version,
  9. Then copy your maps back on your gps receiver,
  10. Connect the gps receiver back on the car,
  11. Then turn it on,
  12. This time it will get passed the blue screen and boot normally.
That is how to solve the problem.
Dec 23, 2010 | Medion GoPal P4425 Navigator System
I have lost my software cd for medion gopal pna315
Google "medion go pal software torrents" (need a multi share to download I,e utorrent,limewire,etc
tc
Sep 28, 2010 | Medion GoPal PNA220XL Portable GPS...
Software update cant be found for my medion p4410 can anyone help pls!!!!!!!!!!!!!!
If you have gone to the manufacturers web site and have found no update for your unit then one is not available for it yet. Keep checking back about once a month and you will/might finally find one.
Jun 11, 2010 | Medion Go Pal P4410 GPS Receiver
My sat nav map is over 12months old how do i update to new map. my sat nav is medion
OK, what you need to do, is go to the GPS Manufacturers website, download the latest software for your unit and PC. Install this as Administrator. Now connect up your GPS via the USB cable. Then turn on the GPS, then update using this software, Reboot and using it's now, updated software, download, any updates, as may be, from the website, it is all done through the GPS's internal program.
Mar 28, 2010 | GPS
We need directions on how to operate our Medion GPS. Can you help? Thank you.
You may be able to download the manual for your device from here:
http://www.medion.com/de/?service/treiber_~u~_updates.html
If you know the "MD-number" of your device (e.g. from a type plate at the back side), enter it into the 2nd field (e.g. MD 98030).
Otherwise, enter the model number (e.g. E3240, printed on the front of the device) into the third field.
Mar 18, 2010 | GPS
Map update
where can I get a map update for medion MD95233
Jun 10, 2008 | Medion GoPal PNA220XL Portable GPS...
GPS Logo
186 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
