The drum does not spin and the main plug get burnt
  • 15,935 Answers
Your motor is toast.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
What would cause my maytag front load washer not to spin? It is a Maytag front load washer and it will not spin. The water drains out no problem just doesn't spin. Also the drum looks lower than it no
The drum bearings may have failed , Or the spin motor winding in the motor burnt out ,
Or the selector switch contacts are not engaging in spin cycle
Jan 06, 2015 | Maytag Washing Machines
Model mah4000aww
Sounds like the main bearing on the back of the drum assembly has gone and needs replacing, the drum has moved out of alignment or the electric motor has burnt out. Best to have a Maytag repair tech or someone who is qualified to look at it.
Nov 05, 2012 | Maytag Washing Machines
Hi, My dryer has stopped dying the my cloths is this a common problem?
No, is the dryer drum spinning? If not, replace the drum belt. If the drum is spinning but not drying the colths. The dryer heating elements is burnt out and needs to be replaced. GB..stewbison
Aug 31, 2011 | Fisher and Paykel SMARTLOAD DE62TG1...
The 2-year old washer leaks from the bottom. At first it was infrequent and now every load. It's in a tray (thankfully) and after two loads the 2" deep tray is full. I've checked the inlet hoses on the...
it sounds like the main water seal has burnt out and all this water is running through the washer drum bearings,,,this will wash the grees out of them so soon the washer will be making a lot of noise as well mostly on the spin speed first,,,
you need to fit new drum bearings and drum water seals,,,
Aug 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
Not working
If you can pump out the water the pump should be OK...The most likely other cause is the main motor. If the drum is jammed it can cause the motor to hum and can make it overheat...You'll have to get the water out. There might be a small drain hose near the pump filter. This will let you test the spin. You may need parts so it might pay to contact a tech........Nomess
Apr 17, 2010 | Washing Machines
VCR VV5106H won't play and heads don't spin
is the circular head drum securely fastened to base? if applicable, is the plug-in on top of or behind it fastened to the main circuit. is the head need cleaning? if so, use a cotton ball swab. w/ alcohol. and likft up diagonally on the drum, not straight up. spin it too. all around it. make sure theres no debris jammed in it.
Aug 06, 2009 | Televison & Video
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
Dec 02, 2008 | Creda IWD12 Front Load Washer / Dryer
Drum is sparking when spinning the clothes
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Sep 24, 2008 | Creda W120VW Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
