Question about ViewSonic PJ550 Multimedia Projector
Projector was working well, and went out when a friend was using it. I thought it would be the lamp, but got a new one and no dice. The power comes on and green, takes a while and finally sounds like it is firing up, but no light, then lamp and power light eventually come on solid red... seems like the lamp is not getting power.. who could fix it?
    New Friend:
When this happens, the Ballast board is broken.
If you are a bit handy, you can get one used on Ebay, and replace the broken one.
Posted on Mar 19, 2013
5 Suggested Answers
SOURCE: dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Posted on Jun 27, 2008
SOURCE: projector
Same problem
When i turn the projector on it only comes on four about a minute until the temp lights go amber and it turns off, the fan is working but the air coming out is a little warm. what if anything is making my projector overheat, or is it not heating at all?
Posted on Aug 07, 2008
projdoc
  • 2237 Answers
SOURCE: Projector power LED was blinking
what model of projector? one can't accurately diagnose a problem without that vital info.
Posted on Nov 06, 2009
  • 72 Answers
SOURCE: LP130 projector - no light from lamp
To operate, the LP130 needs all of the following conditions:
1. Both Front & Rear Fans Operating
2. Front Cover Switch Engaged
3. Color Wheel Spinning
4. Bulb trigger voltage and ballast working properly
5. Good bulb with less than 2,000 hours on lamp counter
If the maximum lamp time of 2,000 hours is exceeded, the lamp will not light. The lamp must be replaced and the lamp timer reset before the projector will operate.
To reset the lamp hour counter, press and
hold the reset button, then press the menu/select button (while
still holding down the reset button) for 10 seconds.
Posted on Jul 23, 2011
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP S30 projector
HI,
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually activate the switch too and it will power up.
For more troubleshooting steps you can see the user manual from HERE
Goodluck,
Please don't forget to rate the solution.
Mar 27, 2008 | Toshiba TLP 261 Multimedia Projector
Turned on the projector and it immediately shut down and now has no power
it seems that the lamp ballast is failing
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
lampdeng@hotma
Mar 09, 2014 | Boxlight Cinema 13HD Lamp
New lamp turns on flashes 7 times
Just a thought...you *might* have a bad ballast in addition to that defective power supply.That flashing could be the ballast trying to ignite the lamp. A lamp is just like an enclosed welder's arc. The ballast generates a high-voltage spark to initially start the lamp, then low voltage with high current keeps it burning. If you look into the lens and see "lightning" flashes but no lamp ignition, that's what's happening. The ballast could've been damaged by the defective supply. Also, try a known-good lamp...just to rule out a defective new one--in the shop, we kept all old working lamps as testers.
Aug 30, 2009 | Sony XL-2100U Projector Lamp for...
InFocus litePro won't turn on.
With a bit of luck a fuse may have blown though almost certainly the lamp has gone. Never **** the projector when the lamp is on.
Aug 28, 2009 | InFocus ScreenPlay 5700 Multimedia...
Optoma EP721 Projector Lamp will not come on
I had the same problem I thought the lamp was Broken orburned out.
I removed the lamp tried  to look at it and see if I could tell if it was burned out or not. Put it back in and it worked.
Oh I forgot! Originally I had loaned it to a friend and it came back broken. The foot at the bottom was broken so I assumed, that it was probably dropped or fell off the table.
So First I bought a second projector because the bulbs were so expensive. Then I did not try to check the bulb for a couple of month's It only had 70 hours on it Anyway Give it a shot. Worked for me
Feb 10, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP Portable Projector - No Power
if the lamp asssembly isnt screwed in tight the unit will not power on. i did have a faulty lamp once, try fitting the old one back to check first. if not the power supply is faulty on the main board or a short in the supply to the lamp can cause this fault.
Nov 01, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
ViewSonic PJ550 Multimedia Projector Logo
88 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
