Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a l5 code what does that mean - Whirlpool Calypso GVW9959K Top Load Washer
  • 15,935 Answers
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
  • blueextc3221
    blueextc3221 Aug 26, 2010
    This error code may also be used if there is a disagreement between the
    motor and machine controllers on the state of the lid switch. The
    control should not allow the unit to run in this condition. This code
    will also appear if the user presses the START key while the lid is
    open. Open the lid or press STOP/CANCEL to clear the display
What does code L5 mean
Google L5 along with the make and model item on which this code appears.
Oct 16, 2017 | Exercise & Fitness
Telsra network unlock code for ZTE Blade L5
Just to the page https://www.unlockninja.com/unlock-zte+blade-l5
make the necessary selection and get the unlock code for ZTE blade L5
Aug 18, 2016 | ZTE Cell Phones
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
Nautilus t714 error code L5. Can you tell me what this error code means? Thank you. Tim
Dear Sir:
I just want to say to L5 means many things.
1)You must check socket wiring from upper board(display) vs lower board(controller motor board)
2)Short circuit in capacitor(EMI) in input circuit or Short circuit in Main Motor Test.
3)Faulty Controller Motor Board-Replace.
4)Realign Sensor Speed Motor and clean or Replace
Since the Controller Motor Board control 90% function in Treadmill , will the most probably cause, after you did Test all Step before mentioned. And strong concluded the Lower Board is Faulty.
sincerely.
If you need further assistance, please reach me.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Nov 22, 2011 | Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
For the kenmore elite oasis he top load washer, what does the error code DL mean and how do i fix it
We jamed a straw in the door lock so the sensor thinks there is something in there
Jul 02, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
