Question about Whirlpool Refrigerators
Not cooling or freezing. fan is running compressor is hot to the touch
  • Whirlpool Master
  • 1,606 Answers
You have a bad overload/relay which plugs onto the side of the compressor . About $40.00 . Take your model number with you when you go to get the part , so you get the correct part . It is easily replaceable , with 2 wires , or , a plug with 2 wires .
Posted on Aug 27, 2010
    Champion:
  • 245 Answers
The only thing that can be wrong when nothing is cooling is a leak in the system. The cost to find the leak is around 400.00. Sorry for the bad news, but that saved you 65 to125 bucks that it would cost for a technician to come to your house and tell you the same thing I just told you. Rate me. Sorry for the bad news.
Posted on Aug 26, 2010
Compressor is HOT, coil is not warm
Check to see if the fan is running down in the back by the compressor, if it isn't put a small fan back there blowing on the compressor, also make sure the compressor is running you can unplug it and block the fan by the compressor wait a few minutes and plug it back in so you can hear the compressor to see if it is running. if it hums and then clicks you probably have a bad relay and overload assy.
Mar 19, 2014 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Its running cool, But not cold, and will not freeze, the fan is running, the compressor is very hot,, I thought it might be that defrost bar, in the evaporator was not working, which would mean its...
Not cooling compressor running... Verify fan by compressor is running. Verify doors are sealing.
Are Coils are hot in the back by compressor? Clean exterior coils.
Jul 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Fan works but the fridge does not coll freezer does not freeze
Does it get cold at all... gots to know...to help hehehehee
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer not freezing, fan in rear bottom of unit not running, condenser extremely hot to touch. ge gdl20kcsabs
Hi, If the compressor is running but the fan is not, you will need to replace the fan motor. First make sure that there is nothing stopping the fan blade.
If you have a window or box fan, let it blow on the compressor to cool it down. This will help you get by until you can replace the condensor fan motor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Refrigerators
Hot to touch
there is another fan at the bottom, rear, of the refigerator. remove the bootom panel and look at the cooling fins to make sure they are not bent into the fan blades. Caefully bend the fins away from the fan. this should improve the cooling of the refrigerator and get rid of the hot spot on the rail between the refrigerator and freezer.
Apr 26, 2009 | Kenmore 53542 / 53544 Side by Side...
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Jan 11, 2008 | Refrigerators
Refrigerators Logo
19 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
