Question about Panasonic Lands Phones
I have panasonic KX-TGA710CX device. How do i register the handset? what is the pin code? thanks, Dani
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Posted on Feb 17, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Panasonic kx tg1100bx kxtg1100cx manual
Did you try to register your handset to the base?
If not then do so , and use the default pin code 0000
or *7000
Oct 26, 2013 | Panasonic KX-TG5632 Phone
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
Panasonic phone KX-TGA710CX - Analog/Digital dialing
what is the recommended battery put in the panasonic kx-tga710cx?can i put ordinary battery or rechargeable battery?
May 27, 2009 | Panasonic Lands Phones
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
The included handset and base unit are
preregistered. If for some reason the
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
KX-TG4321 & KX-TG430B - Purchased separately, can't register handset to base
(Got this from a Panasonic Support Tech...Thanks Panasonic!) The following steps should help.... Resetting Handsets
Oct 22, 2008 | Panasonic KX-TG4321B Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
Lands Phones Logo
110 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
