Question about Alesis Sr 16 Stereo Drum Machine
Sr 16....Hissing sound on all selections. Is there a repare center and what is the charge
    President:
  • 1,138 Answers
You didn't mention your location so here is two links for you:http://en.alesis.com/sales/international.php also:http://www.alesis.com/sales/index.php Your closest listed dealer should be able to give you the service you need.
Posted on Aug 27, 2010
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI
The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section.
1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in.
2. Select the Song to be copied.
3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG.
4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps.
5. Release the COPY and PLAY buttons.
Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E.
Hopefully this helps, it comes out of the SR16 Manual, page 40 I think
Cheers Pete
Sep 25, 2014 | Alesis Sr 16 Stereo Drum Machine
I am not getting any sound with my used Alesis SR-16. I am getting display but just no sound. Help!
Many people have had this problem WHEN they substitued a replacement power adapter.
The CORRECT adapter MUST supply 9 volts AC, NOT DC at 830 ma or more.
The AC is converted inside the SR-16 to both + and - power to run the internal circuits. IF you have connected a 9 v DC adapter, it will NOT have damaged anything, just get the CORRECT adapter and all will be well.
Feb 04, 2011 | Alesis Sr 16 Stereo Drum Machine
In play mode the sr 16 goes beserk. It makes a pulsed buzzing sound and plays back the drums distorted. any ideas?
The SR-16 uses an external transformer as the power supply which provides 9 volts AC. This ac power is converted to DC positive and negative voltages for the digital and analog portions of the circuit. Although the unit has been reliable generally, this symptoms sounds like of of the main filter capacitors in the DC converter circuit(rectifier, filters and voltage regulator) has broken loose or is defective. This will affect both channel equally. If the problem is in one channel, a broken shield on a cable or the output jack ground connection might have broken on that one channel.
Jan 22, 2011 | Alesis Sr 16 Stereo Drum Machine
Just got a SR-16 plugged it in an got boxes in the upper left corner of display. nothing else works. no sound nothing. please help
Make sure you have the correct power adapter for the unit. This unit takes a 9 VAC, 830ma adapter. It will NOT work with a replacement, universal or DC type adapter.
Jan 11, 2011 | Alesis Sr 16 Stereo Drum Machine
Why doesnt my alesis sr-16 have any sound coming out of it?
These of course have to be connected to an external amplifier and speaker.
Check that your amp is working first.
Nov 03, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Oct 18, 2009 | Alesis Sr 16 Stereo Drum Machine
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis SR-16 distorted sounds
The distorted and low volume output plus noise is usually caused by using the wrong power supply adapter. The Alesis SR-16 takes a 9V "A/C" supply not "DC". The A/C supply provides a negative voltage swing which wouldn't exist with a DC supply. So check and make sure you have 9V A/C output supply not DC.
Nov 18, 2008 | Alesis Sr 16 Stereo Drum Machine
Alesis Sr 16 Stereo Drum Machine Logo
199 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
