Question about Microsoft Xbox 360 Console
X box hi i have a sharp aquios 52 inch and when the xbox 360 is on the hd component will dissconect on random and the screen will do black for about 10 seconds they couldnt find a problem with the tv just woundering if it may be the x box 360 console???
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 58 Answers
Hi, I haven't experience it myself but I heard that it might be a faulty cable. Try another cable, if not I it might be the xbox 360 console, I don't think its the TV either.
Here is a similar problem from Microsoft Website:
http://support.microsoft.com/kb/916158
Hope that gave you an answer
Good luck
Daniel
Posted on May 06, 2008
How to hook up Xbox 360 Component HD AV Cable to Sony KP-53hs10
I would be surprised if this model has component inputs from its age and if so it is not a HD set.
Oct 31, 2012 | Sony KP-53HS10 TV
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are...
check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
Apr 05, 2011 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
Aquos screen blacks out with xbox 360 using Component Cables
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Jun 29, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Xbox 360 over Components on LC32D64U
I had the same issue on this set and downgraded to S0801101 and problem solved. Before I did that I called tech support and they had never heard of the issue. I say BS... it's all over the internet. Kind of sucks to have to downgrade to fix the issue. I will say though that it still does it once in a great while on 1080i connected to my TWC HD cable box. I just changed to HDMI for that and all is good.
Dec 16, 2008 | Sharp LC32D62U 32 in. LCD HDTV
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Xbox 360
Hi there
As far as I'm aware the only way to get hd with the older boxes that don't have hdmi socket is through component unfortunately.
Microsoft have indeed pulled a fast one with this and cunningly released the elite for more profit.
I think the only difference betwen component and hdmi is that hdmi has built in audio in one wire where as with component you require seperate audio.
In short, No. HD only via component.
Hope this is of help
Dec 17, 2007 | Microsoft Xbox 360 Console
Screen Goes Blank for about 5 seconds
A friend and I both have the LC-32D64U Aquos sets with the same problem. Black screen for a few seconds with no video or sound. They came with firmware version S0804171.
Installing (reverting?) to firmware S0801101 on Sharp's website resolved these issues. Perhaps you need to update/switch firmware versions, especially if hardware replacement did not resolve the issue.
Aug 24, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
