Question about Toys
Do not now how to put it down - Toys
My car goes into linp mode
You need to put a scanner on the car and read the code. Fix the code and reset the computer.
Oct 14, 2015 | Cars & Trucks
Chevy epica 2004 window goes down wont goes up
is it just the drivers side window ,can you put any of the windows down, if you can put down the other windows you need a new switch,but if you can not do put the other windows then you just need a relay
Oct 29, 2012 | Cars & Trucks
I have a 2003 mazda rx8 its a manuel anyway il be driving in 5th gear and il put my foot down and the rev needle will shoot up and then drop back down while my speed
Yes it is the clutch slipping, in high gear the greatest load is put on the clutch so that is when they slip the most.
Mar 16, 2012 | 2004 Mazda RX-8
I need help finding my WEP key
what you do is go on your laptop or computer then go on the internet and type your ip address on the web search where you type google. (your ip address will be on your wireless router) After you put your ip address in A thing will pop up it will ask you for username and password for the username just put down your wireless router company name like sky or virgin and for the password put down password. Then you will be on your wireless setup web page put your connection name down on the first one then the second bar will ask you for your wep key put down any think then the last bar put down your password then click apply. after that go on your connection click connect or disconnect then click your connection name a thing will pop up it will say passphrase and securitykey type your wep key in it and then your laptop or computer would be working again. And that is how you find your wep key
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
How do I put the top down?
put the car in neutral, pull emergency brake on, and push the top down button. i believe they did away with the manual lock unlock for the roof latch so it should be automatic from there.
Mar 18, 2010 | 2003 Porsche Boxster
It trys to go up and down put will not go up or down without help your can hear the motor trying to work
Take it it's an electric window you have a problem with. Very common in older vehicle's. The rubber seal in the window's harden For safety reasons their is not a lot of power in the motor. Put the window fully down then pour a small amount of oil down the runner's each side. Put the window up and down pouring small amounts of oil until the window is going up and down freely. Leave for a day using the window as normal then clean off any excess oil. The oil softens the rubber
Oct 13, 2009 | 1994 Ford Explorer Limited
How do you put the batteries in the Vivicam 5022 digital camera???? Which way do they go????
The batteries are put in so that the first battery positive end is down, the negative down second, and the positive end down last.
After you've put in the batteries (-+-).
Sep 01, 2009 | Cameras
Putting it down!
hi pull up the to leavers on handles at d same time push handles down u will notice that at the bottom by wheels it has uncatched now pull on the handle at back and it should fold it does take a while to get d hang but its easy once u no how. hope this helps.
Nov 23, 2008 | Silver Cross 3D Stroller
How 2 unlock my sounds and multimedia? forgot my code.
I have a ? about my security code for my sounds and pictures because i just can't remember what code i put down. But my main ? is is there any universal code that u could put down that will help me unlock that code, or what can i do?
Apr 28, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Toys Logo
13 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
