Question about Brother SX-4000 Typewriter
How do u change the margins on the type writter
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around there tou will find a manual.
DickyO
Posted on Aug 27, 2010
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
Problem of dvd/cd writter
check the IDE/SATA cable,if its connected,now u must to become sure from lens.maybe it need to cleaning.therfure,if after cleaning this problem still apear,so u must change the board or somethings in it by testing
Jul 07, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
How do i change the font type and size on a "brother ml 100" type writter?
To change the type style or size replace the printwheel and adjust the pitch.
Go to brother.com click on support you will find a manual there with pictures.
DickyO
Mar 29, 2010 | Brother ML-100 Typewriter
Can't change the right margin
You must first position the carrier to where you would like the margin to be set, so if you want the margin to the right of where it already exists you must to the the margin and Depless the margin release function (M rel). If the typewriter is in line-by-line mode you may have to select the TYPE mode , before you do this. When the carrier is position to the place you want depress the R margin set function (CODE plus M left)
Nov 25, 2009 | Brother EM-530 Typewriter
How to change the pitch?
Here ya go...
Margins and Tabs
Margins and tabs for both Type Mode and Mem Mode are set in Type
Mode, but can be changed in Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to Type. A typing scale appears on
the display.
2. Move the cursor using the Spacebar or Back Space to the desired left
margin setting on the scale.
3. Press Margin.
4. Move the cursor using the Spacebar to the desired right margin
setting on the typing scale.
5. Press Code + Margin. A beep confirms each new margin setting.
6. You can change to Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 02, 2009 | Office Equipment & Supplies
What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Oct 27, 2008 | Brother GX-6750 Typewriter
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
Nov 29, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Brother SX-4000 Typewriter Logo
14 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
