Question about HP Photosmart C4100 series
When i turn the printer on it says ink cartridge problem.remove and check color cartridge.message won't go off
  • Anonymous Mar 30, 2014
    turning on printer, display says "Ink Cartridge problem, remove and check color cartridge...I do that and insert cartridge in again and the same display comes up
You might have solved this issue by now, but same thing happened to me and I simply removed the cartridges and any of the leftover orange debris on each indivdual ink cartridge from those removable tabs might cause your issue. I scraped it off and the first time I reinserted the cartridges the issue was solved
Posted on Dec 27, 2010
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
I intalled new ink on my computer and it says to remove tape from cartridge when I all ready did and it will not work
Unplug the printer from the wall. Noe remove the power brick from the printer for 60 seconds. This will reset any error message the printer is getting. Plug the printer back in.
Turn on the printer. Open up the printer and take out the black cartridge and reseat it. Do the same for the color cartridge. Now close the printer and it will print an alignment page. Any error messages?
If you still get the error message, then it's possible that the sensor in the Dell Series 5 ink cartridge is bad. If this is a new Dell Series 5 ink cartridge, then take it back to the place of purchase for a replacement or refund.
black = black side(left) color = color side(right)
photo cartridge = black side(left color = color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to purchase a Dell Series 5 ink cartridge with a bad sensor. Please take it back to the place of purchase for a replacement.
Rick
Jan 10, 2011 | Dell 962 Photo All-In-One InkJet Printer
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Message in LED is ''Remove and check color cartridge''
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Computers & Internet Logo
359 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
