My washer makes a heavy noise on spin cycle, as if I had put a brick in it. It's only 6 years old.
  • Washing Mach... Master
  • 2,699 Answers
If it's a front load washer,buy a new washer,the spider gear is gone.usually it's from using to much detergent.there's very little water that gets used in the front load washers so you only use very lttle detergent,it eats the gear in the back of the washer,open the door and push on the tub,if it moves all around with ease then i wouldn't use it,i've seen the boot rip off and water leak everywhere,also you could have broke a shock but it brakes from the spider gear being damaged.sorry to give you the bad news but get a new washer,the spider gear costs around 500 bucks,next time watch the cd that comes with the washer and do what it says and cut back on the detergent
Posted on Aug 26, 2010
Testimonial: "thanks!"
What causes a very loud noise like a jet taking off when the spin cycle starts
If its a front load washer then the rear bearing is wore out. This involves a costly repair
Aug 20, 2014 | Washing Machines
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Duet Washer spin cycle makes noise
if it was from a heavy load more than likely 2 screws came off of the tripod on the back of the metal basket.
take of the front lower panel of the washer and clean out the drain pump, if the screws came out they should be in there. to actually fix the problem you would have to take the entire tub assembly out and apart to get to the baskside of themetal basket.
but in general, its not that hard to fix if you are mechanical savvy. i fixed mine myself and im a 27 yo female who has never looked inside a washer before this experience.
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
