Question about Motorola Mobility RAZR V3
Replacing v3 axis piece.
Does anyone know how to totally take the top off the phone? there is that sort of spring loaded axis piece in there and i can't figure out how to get the flip portion off because that thing is in there and it feels like something is going to break if i force it. i assume i will have to separate the two halves to replace the flex cable, but even if not i would love to know if there is a trick to it or what. thanks for any info.
  • cingular426 May 07, 2008
    I am having the same problem. The side where the flex cable is loose and appears oly the tip of the cable is keeping it from coming off. The other side looks like there maybe something tgat needs to push inwards, but I don't want to force it.
    Scholar:
  • 181 Answers
Error code 05,004,44:11367 on Xerox phaser 8560DN
Hi tonyswain:
This is your problem.
Run the Y-axis Drive test.
2. Check the current values.
3. Are the values within normal operating
range?
Go to Step 5. Replace the
Y-axis motor.
5 1. Run the Y-axis Belt Tension test.
3. Are the values within the normal operating
range?
Go to Step 6. Replace the
Y-axis belt.
6 1. Run the Y-axis Motor test.
2. Did the tests pass?
Replace the
drum assembly.
Replace the
Y-axis motor
Hope this helps
pdouglasss@hotmail.com
May 22, 2009 | Xerox Phaser 8560DN Laser Printer
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Can I replace the hinge of my motorola V3?
yes you can but have a tech replaced it for you
Nov 23, 2008 | Motorola Mobility RAZR V3
Can't hear caller unless I put it on speaker
the ear piece needs to be replaced on the phone
Sep 28, 2008 | Motorola Mobility RAZR V3
Ge washer dryer wsm2420
Those clips are plastic and the top should just pop off with a little prying on the sides. However, if the drum is off keal, its probably because a balancing spring on the bottom has either broken, or somehow come off. you would need to take the front and sides off of the lower unit, and find the springs and make sure they are connected to the tab that receives them, protruding up from the bottom of the washer frame.. There is usually a plastic piece on it, that has what looks like "teeth" where the spring would set into. Its hard!! make sure all springs are in the same position (grooves) before putting the machine back together. Also remember not to overload the machine, nor wash very large items such as comforters. Once the damage is done by one comforter, you will have to go through this whole mess to fix it.
Jun 08, 2008 | GE WSM2420T Top Load Stacked Washer /...
How to remove battery on Razr2 V9?
I have a RAZR V3C and the rear battery panel has to be removed first to gain access to the battery.
Looking at the rear of the RAZR and at the top, there should be a chrome spring-loaded panel that you can push in with your finger nail. That will unlock the rear panel.
Once the battery cover is removed, the battery will pop out by grabbing ahold of it at one end and lifting the end up and out.
Let me know if I can be of further assistance to you.
- Jim
Feb 07, 2008 | Motorola Mobility RAZR V3
Tries To Come on, But Screen Will NOT Light Up!
hi there.
the problem your having is caused by a ribbon that connects the screen and the mainboard in the phone.
the ribbon seems to have either come loose or detached.other than that being a problem it will almost certainly be a screen issue where the lcd has burnt out.
but in my professional opinion it will almost certainly be a ribbon issue
Dec 09, 2007 | Motorola Mobility RAZR V3
V3 RAZR constantly pressing right?
As you describe it, your problem is the keypad. Maybe dirty or wet inside though that part is a totally replaceable pad with a connector only so you must buy a replacement and replace the broken one.
About how to do that: being the razr a common phone is pretty sure you'll find guides, photos and maybe videos around the web, googling, guiding you on how to do it. Maybe the shop where you buy the replacement can have a forum or guides.
The other option is to pay a technician to do it.
Good Luck...
Oct 20, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
