Question about Sharp AR-M450N Copier
My arm-450 sharp copier gives code L6-10 when I try to use it how do I fix this problem?
  • Sharp Expert
  • 1,326 Answers
You can try to clean the laser poloygon motor, but you will only have the same problem come back again. The best fix would be to replace the laser poloygon motor... It can not be cleared till it is fixed. Good Luck
Posted on Aug 27, 2010
L have a sharp printer model arm 450 problm h4:02
Good morning .
There is no H4-02 in the manual .
All H4-xx codes are fuser related so be careful .
It could be a paper jam round the fuser or a worn thermistor etc.
Jun 14, 2016 | Sharp Office Equipment & Supplies
Tip
F2-02 error code on Sharp AR-M350/450 and 355/455 Copiers
The F2-02 code will often be the result of a defective or after market toner cartridge. Try replacing the cartridge and power cycling the copier before placing an expensive service call.
on May 17, 2010 | Sharp AR-M350U Copier
Install toner
toner not supply properly. please change chip for this copier
Apr 16, 2014 | Sharp Mx-M450 Copier
It's a arm 257 copier with a code f5 -02 ran the
clean white surface under the glass and also mirror under the lamp be carefull to lamp
May 21, 2010 | Sharp AR-M237 Copier
CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
On a sharp arm 257 can you a drum unit or just blade and drum
Did you mean drum frame unit ? This frame include all the spare parts of drum unit except drum and drum fixing plate. The code number is AR 310 DU ( DRUM FRAME UNIT ).
DRUM : AR 310 DR
CL. BLADE : AR 271 AK
DEVELOPER : AR 271 SD
Jun 03, 2009 | Sharp AR-M237 Copier
Sharp ARM-455 F202 error code and says check toner cart.
There is any solution for error F2-02 without changing any Toner Cartridge
Jun 05, 2008 | Sharp Office Equipment & Supplies
Sharp AR-M450N Copier Logo
90 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
