Question about Epson Stylus Photo R220 InkJet Printer
How to change waste pad??
My printer is blinking?and i think the waste pad is now full??what should i do??
    Novelist:
  • 144 Answers
Hello!
try this and check if it will work:
1. Press and hold "Stop", "Maintenance", and "Power" buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don't have a screen so just wait until the 10 seconds is up. 2. Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That's all there is to the reset procedure. Is the waste pad full ? If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer. Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way. Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel. Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved. If you wish you can make a hole or notch in the access panel cover so it can be replaced. Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Posted on May 06, 2008
  • serra baby
    serra baby May 06, 2008
    hello!
Epson P50 does not respond. Blinking lights and stuck cartridges.
This is a standard "Service required" issue where the waste pads (or nappies) in the printer are considered full by the printer and it wants them changing.
An Epson service centre can replace the pads and reset the waste counter for a considerable amount of money although most it seems either tell you it's dead and recommend you buy a new one, or they reset the counter, ignore the pads and leave you to flood your printer.
The more cost effective option is to locate one of a number of reset utilities such as the AdjProg utility for the T50 (it's compatible with the P50) and an external waste ink kit (like the Printer Potty).
The latter is easy enough to fit on a P50 thanks to the access hatch located in the rear left quadrant of the printer.
More information and instructions are available here:
http://www.wasteink.co.uk/waste-ink-mods/epson-r285-mod/
Jun 29, 2012 | Epson P50 Inkjet Printer
R 300 have three light blinking Red ink light, basic and advance light blinking green will not work
most probably the waste ink counter is full.. you will need to reset the waste counter and replace the porous pad..
Apr 03, 2011 | Epson Stylus Photo R300 InkJet Printer
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
There's a general problem to my Epson TX100. the two orange light is blinking. What should I do? Do I have to reset my printer? What software should I use?
You have to reset your printer. Go to this link to download the program.
http://www.ngedownload.com/epson-tx100-resetter-wast-ink-pad-full.htm
NOTE: you have to replace the waste ink pad inside your printer to prevent flooding of waste ink.
Jan 19, 2010 | Epson Stylus NX400 InkJet Printer
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
Waste Ink Near Full
Try this:
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Let me know the result.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Office Equipment & Supplies
On light just keeps blinking, and blinking, and blinking
the printer waste pad my be full and the printer needs to be reset if you download the ssc this my reset your printer
Feb 28, 2009 | Epson Stylus CX4600 All-In-One InkJet...
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
Waste tank full
Inkjet pads are between the printer chassis and the bottom of the printer case. Typically a large felt pad.
My Canon i9100 has eight orange flashes and indicates on screen "waste ink tank is full". After opening up mine I found this to be false, only one third soiled. This then leads me to believe the i9100 has a timer to go off after a preset number of hours.
Anyone know how to reset the "full waste ink tank" error?
Dec 08, 2007 | Canon i9100D (Bundle) Photo Printer
Epson Stylus Photo R220 InkJet Printer Logo
499 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
