Question about HP COMPAQ Presario SR5510F Athlon 64 X2 5000+ 2GB DDR2 500GB NVIDIA GeForce 6150 SE Windows Vi... PC Desktop
My computer freezes and makes a long beeping sound then no signal to monitor, beeping continues till manually shut down.
  • 119 Answers
There are several reasons why a computer will lock up. You can view the HP help file HERE for your computer. You can also view the beep codes for your computer (yes, those noises mean something :D ) HERE. The instructions are step by step for your machine and should be fairly easy to follow.
Good Luck
Posted on Aug 26, 2010
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
No picture and desktop makes beeping sound
Base on the post codes this continuous beeping indicates a power problem. Atypically this is a power supply problem and it will need to be replaced.
Oct 06, 2009 | Computers & Internet
Data is not sent to the monitor
The first thing to do is to pay attention for "beep" when your press the power button (or the reset button) to turn the computer on or reboot it. The beeps that a PC makes tells you a lot about the state of your computer. I couldn't quote for you the exact beeps to listen for, but your manual for your motherboard may tell you. Different beep pattersn tell you what is wrong with a computer.
I think for many common motherboards it is something like 4 beeps to tell you the graphics card has failed. Don't quote me, but that is at least along the lines of how it works if not the exact number.
If you're getting no display after starting your computer make sure you hear one beep. Then, listen for other activity. If you're computer has a floppy drive, listen for the 'floppy seek'. Otherwise, listen for hard drive activity. If it sounds as though there's activity along those lines but still no signal/display on the monitor perhaps check the cable between your PC and the monitor. Never hurts to just make sure the monitor is turned on of course.
If your monitor is on, and the cables are connected securely I wold restart the computer again and check for the beeps. I would be certain to count them and check the manual. Your graphics card may have failed if you hear abnormal beeps (more than one as one is usually the healthy indicator). If you hear no beeps then the PC is not even getting in as far as testing it's devices and could quite possibly be a motherboard failure.
Dec 19, 2008 | Dell OptiPlex GX110 PC Desktop
Beeping sound
take out the RAM then put it again, then check
Nov 02, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Alarms
Hello, find the BIOS Beep Codes at http://www.amptron.com/html/bios.beepcodes.html and try to find your problem. It is not a software or Monitor problem. It could be RAM or Video Card failure
Aug 04, 2007 | Biostar M7VIZ Motherboard
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
HP COMPAQ Presario SR5510F Athlon 64 X2 5000+ 2GB DDR2 500GB NVIDIA GeForce 6150 SE Windows Vi... PC Desktop Logo
278 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
