Question about HP Laserjet P4015x Printer
I have a new hp laserjet 4015x that keeps giving me an error code 59.00.
  • 292 Answers
Thank you for contacting FixYa with your printer inquiry.
59.xx is usually associated with a main motor startup error. A main motor error occurred.
X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error
Actions:
  1. Power cycle the printer by turning the printer off and then back on. Listen for motors.
  2. Open the printers back panel and remove the fuser. Check for paper jams then reseat.
  3. Check the toner cartridge and make sure nothing is hindering movement in the gear train.
  4. Check the main motors cable to make sure it's seated properly.
  5. If the error persists then replace the main motor.
Parts Info: http://partsurfer.hp.com/Search.aspx?SearchText=CB511A See Motor Section.
RL1-1657-000CN - Main drive motor (M101) - Drives the tray 1 pickup roller, tray 2 pickup roller, and feed roller.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Posted on Jun 14, 2011
  •  Steve
    Steve Jun 09, 2014
    Before you go spending money, turn off the printer. Remove the toner cartridge. Replace it. Turn on the printer. This fault is usually associated with remanufactured toner. There is a bind in the cartridge causing the main motor to have difficulty turning.
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
HOW CAN PRINT ON TWO SIDES ON WINDOWS 7 FROM HP LASER 4015X
Hi! you must change to twosided printing in printing preferences or in printers setting console.
May 30, 2011 | HP P4015X LaserJet Printer with Automatic...
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Mar 30, 2011 | HP Laserjet P4015x Printer
Hp laserjet 3550 keeps on giving me error message of code 59.99 what do i do to solve the problem please thank you.
ur developing motor gears worn out replace them ur problem will be resolved...............
and
This error also shows the faulty secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
3. Faulty feed motor.
Action: Replace the feed motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
good luck, and do rate the solution if helps
Nov 30, 2010 | HP LaserJet 3550 Printer
I try update Firmware for Hp 4015n, but unsusscess. Now LCD display 6/6 A/F. pls, help me
I had the same problem with a 4015x. HP Support advised me to deinstall the additional paper tray and the toner and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Make sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Oct 12, 2010 | HP LaserJet P4015N Printer
Have a network hp 4015x printer and for the life of me I can't stop it from wanting to print to tray one. I have installed the lastest firmware and driver from HP. Any ideas?
unless in your printer preferences it's set to tray 1 -(manual feed), the problem could be that a clip or something is broken in tray 2 - seen that many times.
Jun 14, 2010 | HP LaserJet P4015 Printer
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
HP Laserjet P4015x Printer Logo
395 people viewed this question
Seeker5211
Seeker5211
