Question about Nintendo Wii Console
We are unable to get an internet connection - Nintendo Wii Console
  • 864 Answers
Try to use the trouble shooting guide i have provided below. if you need further assistance please let me know and i will assist you from there. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Posted on Aug 27, 2010
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Why after installing webroot on my hp pavilion with windows 7 I can not connect to Internet it says " unable to connect to proxy server" ?
The anti-virus has set up a firewall which has disabled your internet access. Go into your Webroot console and go to settings and firewall and set it to make an exception for incoming network connections.
Sep 22, 2014 | Webroot AntiVirus with AntiSpyware &...
I HAVE a micromax Q7 HANDSET BUT WHENEVER i OPEN OPERA MINI AFTER LOADING IT SAYS FAILED TO CONNECT TO INTERNET I AM UNABLE TO ACCESS INTERNET PLZZ SUGGEST ME IHAVE AIRCEL CONNECTION
i have a LG handset but whenever i open opera mini after loading it says failed to connect to the internet i am unable to access internet PLS suggest me i have suncellular connection
Apr 01, 2011 | Opera Software Browser
I have a acer aspire 5570Z, unable to connect online...
Open network connections and disable your wireless connection (right click) then renable it and try to connect. What program are you using to manage your wireless connection?
If you are using your manufaturers software then try using windows xp (or vice versa)
Aug 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Unable to connect o any programmes or internet,
Do you have a firewall installed? Check it's settings and make sure the settings allow connection to the internet.
Aug 23, 2009 | Fujitsu Siemens Computers & Internet
Message ''unable to connect'' i do not use a provider....
Is it a dialouge box that appears?
or it says "unable to connect to the server host not found"?
please describe little more.
if its for internet, simply go to Network connection and disable "local Area Connection"
Mar 25, 2009 | Computers & Internet
No internet connection on my e-machine need your help
on the bottom right of the screen do you see the 2 little computer monitors, and are the flashing. if they are there double click on them and see if it says connected. if not your network card may not be set up properly.
Mar 12, 2009 | Computers & Internet
Unable to connect to the internet
Please contact your Internet service provider.
OR check your connectivity settings
Jun 27, 2017 | Palm Treo 750 Smartphone
Unable to download anything from internet
check your Internet ambition, it is obvious that your Internet Connection is breaking Jethro. check with the connection or with the Server saved luck.
Jun 26, 2008 | Microsoft Windows XP Professional
Internet
check your utp cable connection, if you think that your cord is ok then run the network wizard from the control panel, there are some reasons of unable to connect the internet, the connectivity, defective lan card and so on
Mar 12, 2008 | Computers & Internet
Nintendo Wii Console Logo
14 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
