Question about Frigidaire FAC126P1 wall/window Air Conditioner
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
  • Frigidaire Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
I have a Crosley 220 volt 18,500 btu window unit air conditioner with a heat pump. The cool air works fine when set on cold, but when set on heat, it doesn't blow warm air. What should I check first?
18000 BTU Air Conditioner ' The Air Conditioner Guide
www.theairconditionerguide.com > BTUs
An 18000 BTU air conditioner is your best bet if you are looking to cool a room ... 2) Frigidaire 18,500 BTU Window-Mounted Median Air Conditioner with ...Troubleshooting Guide. Lost your Everstar air conditioner manual? Fix it tips are here!
Nov 26, 2015 | Crosley CAHE18ER Air Conditioner
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
The blower dosent work on my fra124ht1 frigidaire ac what can be done
If the unit is not producing any cool air, then you must see if there are replacement parts available for this unit from your manufacturer. Some units, this small, do not have many parts that can be purchased and repaired.
Jul 18, 2012 | Frigidaire fra12h1 wall ac,12,000 btu 120v
I have a Emerson Quiet Kool Model # 12JW42K that is 13 years old. It doesn't seem to cool the apt. anymore. I assume that it would be smarter to get a new "energy saving" unit than invest in...
I know that a Island Air units come in all shapes and sizes and they make a ton of different units. They are made in new york thats who I would use. I would definitly go with the 12,000 btu unit 500 square feet needs 12,000 btus 10,000 is under sized. 500 square feet divided by 500 = 1 ton of cooling. let me know if I can further assist.
http://www.islandaire.com/
Jul 23, 2011 | Heating & Cooling
Brand new delonghi PAC C120e, I got everything installed easily with the unit rite next to the window, I have it turned all the way down and it still does not cool my small room at night. It seems to blow...
Since the unit is new and under warranty and hopefully you have registered it with Delonghi. Your best bet, is to contact their Customer Support Rep 800-322-3848. Doing it this way has you totally covered.
Jul 12, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
Frigidaire window air condition unit
Hello,Lilo The styrofoam pack MUST stay in place.When in operation the air tempature is so cold the unit will condensate(create water)if not insluated.Your unit would LEAK all over the place.The blower fan is a PLASTIC composit and should not rust.
Apr 24, 2010 | Frigidaire FAC126P1 wall/window Air...
10,200 BTU a/c blows air but not cool air
They can freeze up if the outside air is too cool. It needs to be over 65 degrees outside and inside. Another possibility is if the unit is a little low on refrigerant. They will run too cold if slightly under charged or if the condensor is very dirty and the heat can not be exhuasted.
Aug 27, 2009 | Heating & Cooling
Does not seem to cooling very well
clean both the evap coil and the condensor coil
Jul 13, 2009 | Amcor NanoMax A12000E Portable Air...
Just bought 12,000 BTU unit from Lowes. It worked
you have to balance the adjustment of fan speed and the amount of coolness you set the unit for. Either increase the fan speed or lower the coldness setting.
Jun 24, 2009 | Heating & Cooling
Frigidaire FAC126P1 wall/window Air Conditioner Logo
246 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
