Question about Car Audio & Video
Vw polo 1997 not starting 1.9 d
Dear sir
my polo 1.9 d not starting, Eng turns but will not start, heater plugs good, put test light from top of plugs to earth, switch on eng no power to plugs. Replaced temp sensor not solved prob. To start car I put wire from + bat to top of plugs for 6 sec this gets me going but not solving the prob.
Please can you help Trev
  • hornby May 09, 2008
    Thanks problem solved.
    I've sold the car.
    A now happy Trev.
  • 26 Answers
Check for shorts in the plug wires.
Posted on May 09, 2008
I have a vw polo 2002,when stuck in traffic or after long drive,the ar goes off
does the temp gauge reach the red area? check eng coolant .Over heating could cause eng to cut out so as not to cause more damage check the cooling system.When travelling slowly or at stand still turn heater to max heat and max speed this will cool eng but is only a temporary solution
Mar 26, 2014 | 2002 Volkswagen GTI
Volkswagen Polo hot start problem
1) see the diagram
2) use the scanner and computer test, this will guide a exactly problem
3) reset the igntion timing, it doesnot matter if your system ha BCM, adjust to accoridng the specification manaufacturer, because the BCM runt according to the information recorderd. remember the BCM =CPU.
4) test the sensor cam/crank with VOM see the diagram.
5) the head gasket i blown, valve timing is incorrectly set. the exhaust system is blocked.
Jul 18, 2012 | Cars & Trucks
Heater Blower fault for Polo
this sound like the fan motor itself. remove the blower fan from the car(its on the passenger side below the glove compartment) and bench test it to see if its straining or maybe something jamming it. not uncommon to get a bunch of leaves in there or i have seen nests once or twice.
Feb 03, 2010 | 1997 Volkswagen Golf
VW Polo Steering wheel warning lights went on last week, checked fluid level , seems a bit low and have topped it up, and lights still stay on, the steering seems working ok now but light remain on, the...
If its the electronic unit,check the main fuses near the battery,also check the wiring connectors at the powersteering pump for loose or corroded plugs.If alls ok,you will need a diagnostic machine to read out what trouble codes are in the units memory.good luck.
Sep 14, 2009 | 2002 Volkswagen Golf
Vw polo 97 1.4 missing on 1 cylinder, checked the basics, plugs n leads, dizzy cap n rotor arm hasnt made any difference. can u help?
have you isolated which cylinder is misfiring?
either way I would have a compression test done .. to find out which cyl is not firing pull 1 spark plug lead off at a time until you get the one that makes no difference
Aug 20, 2009 | 1997 Volkswagen Golf
Vw polo heater blowing only cold air
Daughter's R reg VW Polo has heater probs, only just started, fan working fine and temp gauge works normally but only blows cold air. What do you think could be the prob ?
Mar 25, 2009 | Volkswagen Fox Cars & Trucks
Vw polo car wont start
try disconecting the coolant temp sensor and then try, it may be faulty, also check the hall sender unit in the distributor, if it has one, the centre pin should be the signal wire if no pulse is present the sensor is faulty
Jan 03, 2009 | 1997 Volkswagen Jetta
Sequence for spark plug leads on a vw polo 1.4 1996
Hello darren625, the firing order will be 1-3-4-2, #1 will be at the front of the block,I am not familiar with volks wagon but you can disconnect the power (to be safe) turn the engine over by hand with plugs out for ease use a piece of stiff wire or small screwdriver in the #1 plug hole and you will feel the piston come up make sure it is on the compression stroke (you will feel air escape) when it is at the top before it starts to travel down that will be tdc (top dead center) the rotor will now be in line with #1 connect wires as per firing order and you should be good to go,hope this helps, good luck
Nov 06, 2008 | 1996 Volkswagen Golf
VW POLO 1.6 2002 classic
I have already a solution to my problem. Remember, when I posted, that my 1997 VW Polo Classic, that it won't start even it has sparks coming from the "spark plugs" and the timing was set already. Yesterday, My mechanic was puzzled, why the intake manifold has a very low pressure. Just this morning when he opened. It was clogged with "tartar" like material. It includes the valve & piston. Therefore, it is impossible to have combustion. Because, it lacks the fuel & air even how much sparks is present. I hope this could help to VW cars owners having the same trouble.
Oct 01, 2008 | 2002 Volkswagen Jetta TDI
Car Audio & Video Logo
233 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
