Question about Roper RES7646KQ Electric Dryer
Roper dryer belt install - Roper RES7646KQ Electric Dryer
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Aug 26, 2010
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: roper dryer
One of them drum wheels is bad.To get to it: Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out and inspect the wheels.
Posted on Dec 31, 2008
  • 64 Answers
SOURCE: how do I get at the belt on a Roper Drter?
YOU HAVE TO TAKE THE FRONT OFF TO GET TO THE BELT. TO DO THAT YOU HAVE TO POP THE TOP UP , THEN YOU CAN GET TO THE SCREWS TO TAKE OFF THE FRONT
Posted on Sep 14, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Posted on Apr 09, 2010
How do you install the belt that turns the drum
I can send you a roper belt diagram it is easyer to email it to you just give me your email address and I will send you some illerstrations please give me a good rating if happy thank you
Dec 08, 2011 | Roper Dryers
Need belt diagram for Roper dryer RES 764 6KD2
this link http://www.repairclinic.com/Dryer-Belt-Diagrams is belt configuration of all different brank dryers,The roper is either going to be diagram H or K refer to chart to see which yours will be based on the back panel
Aug 21, 2011 | Roper Dryers
I have a 9 year old Roper dryer. Went in today to turn it on and the motor sounds like its running, but there doesn't seem to be anything turning and I hear a high pitched squeaking sound. Any thoughts??
The problem is likely the dryer belt . Here is a video Dryer belt replacement video . It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Roper REX4634KQ Electric Dryer
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
I'm trying to figure out where part #3346 goes on a roper REX5634. Pretty simple right? But I can't find it anywhere and no where looks obvious. help! Pleeez
if your part number is correct it would be the idler pulley tensioner for the drum belt and installs right next to the dryer motor inside the units lower area to keep belt tension on the drum belt
Feb 02, 2010 | Roper REX5635E Dryer
How do I get at the belt on a Roper Drter?
Sep 13, 2009 | Roper RES7646KQ Electric Dryer
The belt broke drum won't turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
Putting the belt back on a roper ras6233kq1?
HI thanks for your question. so I assume you have the dryer apart, and just don't know how to install on the pulley. . after the belt is on the drum and the belt is hanging.. double the belt and push under the idler pull y , and then on to the motor pulley. thanks . please rate my answer. thanks the appliance doc.
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper dryer not working
If the drum will not rotate, look for a broken belt or even possibly a faulty motor. If it is a belt, it should be relatively cheap to repair and possibly easy for you to aquire the specs on the breakdown of the dryer to access the belt for installation. If the belt isn't broken, then the motor is possibly shot and I am unsure of how much ROPER parts are. Be model number and serial number SPECIFIC when ordering parts, and don't go with the "SUGGESTED MATCH" just to save money if you can avoid it, they aren't always compatible.
Mar 14, 2008 | Roper RES7646KQ Electric Dryer
Roper RES7646KQ Electric Dryer Logo
69 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
