Question about Maytag MSD2756G Side by Side Refrigerator
Freezer works fine on my Maytag side-by-side refrigerator, but refrigerator is not cold enough, there is is ice accumulated inside the vent between the freezer and the frig., specially on humid days.
    Champion:
  • 245 Answers
Defrost your fridge with a blowdryer in the freezer after you remove the freezer back panel. Get the ice out of your exhaust pipe going to fridge. Your evaporator fan should be running, either your defrost heater is bad or your defrost thermostat is bad. I ussually replace both. Good luck rate me if I am correct.
Posted on Aug 26, 2010
Testimonial: "Thank you, you were right. I agree with you. I'll do the the procedure now."
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
HAve a MAytag MZD2766GEQ Refrigerator. It is
the defrost timer. its under the control panel in the fridge section
Feb 11, 2010 | Maytag MZD2766GES Side by Side...
Refrigerator side doesn't keep things cold, just cool, despite having it on the coldest setting and the cold vent open between the freezer. The freezer is working fine.
Look on the back wall of the freezer for a ice buildup. If there is ice you have a defrost problem. The defrost timer is in the fresh food section inside the control panel.The defrost heater and defrost thermostat are behind the freezer back panel inside the freezer.
Also check the freezer fan. If there is no ice buildup in the freezer the freezer fan motor could be bad.
Nov 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Maytag side by side, msd2456de will not make ice, I have water that dispenser works fine, I believe freezer is cold enough what could be the probem?
If water is not getting to the ice maker the fill ice maker with tap water. Wait until it freezes and dumps and then replace the dual water control valve on back near floor. Sea Breeze
Jul 20, 2009 | Maytag MTB1504A Top Freezer Refrigerator
Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
many times when a unit has a defrost problem the coils freeze up and do not allow the fresh food side to cool properly...check for a build up of ice on the inside back wall of the freezer compartment. if there is a build up of ice, you have a defrost problem. Also, check to make sure the evaporator fan in the freezer is blowing the air into the fresh food side.
Dec 26, 2008 | KitchenAid KSRS25IL Side by Side...
Ice on the back wall of the side-by-side freezer and no ice
Possible circulation fan has quit, or defrost element is not working, call service.
Apr 20, 2008 | Haier HTE18WAA Top Freezer Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
94 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
