Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Where can I get a black door panel for my Hotpoint Dishwasher.Mod # HDA 200x-68ba. I think the part number is EAP 26126
    Champion:
  • 246 Answers
Go to www.applianceart.com they have all kinds of colors and panel options. they have designs, colors, textures, holiday ones, and even stainless steel. www.applianceart.com
Posted on Sep 08, 2010
My Hotpoint dishwasher won't drain. What can I do? HDA 3740 Go2SA are the numbers on it
Look for the fill float on a corner of the unit. Does it move freely? Is it waterlogged? This signals filled and empty depending where in the cycle it is.
Mar 12, 2018 | Hotpoint Dishwashers
I'm trying to find out info on Hotpoint dishwasher catalog # 40mc20
That number is not a factory Hotpoint model number, you need to get the Hotpoint model number, which starts with #HDA*******(example#HDA1100NWH) then go to www.hotpoint.com and you will find info on the dishwashers.
GOOD LUCK !
Aug 09, 2010 | Hotpoint Dishwashers
Leak on the side of the dishwasher - help please....
lets step back and take a look at this,this is the way a dishwasher works.1water in.2wash.3water out,that it.i just cant see this hose going up and down a rule the water goes straight out via the pump.let me stop you there and say follow what i have said and go back and have a good look and come back to me on this problem and i will help you.adrian,,,
Jul 02, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Two Black panels on bottom of diswasher removed
Try www.applianceart.com - I think thats the panels you are referring to? Otherwise, the manufacturer will be able to help you for a steep price.
Jun 21, 2010 | Hotpoint 24 in. HDA3400G Built-in...
I have an lg dishwasher mod#LDF7811ST, get error codeIE, changed the inlet valve, machine worked once then got IE error code again. Any suggestions?
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Apr 28, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
How to remove bottom panel on front of Hotpoint model HDA 465-01 Dishwasher
two different models one is lean it back two screws hold the complete base on and you just twist the pump off. the other you can access the pump from below the internal filter on the left one torx screw and you can see if there is anything blocking the pump. regards
Feb 12, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
82 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
