Question about Kitchen Ranges
NEED WIRING DIAGRAM TO REPLACE HONEYWELL ST9120C 2002 WITH ST9120U
Honeywell ST9429C Flashes a message saying no signal. Have replaced batteries but no good
RF signal path between the ST9120C and the CS92A maybe blocked by an object or another wireless device. Check the direct path between the two devices and reposition any object that may be blocking the signal, or move the thermostat. also check if batteries are fresh.
Jan 06, 2018 | Honeywell Heating & Cooling
I need a wiring diagram for a thermostat
the new honeywell should have a wiring diagram with it.
Jan 28, 2016 | Honeywell Heating & Cooling
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
St9120u
The X and C are the incoming low voltage from the transformer. They go to the X AND C with the xtrfm in the middle. Hopefully you marked all your motor leads!?!
Nov 28, 2017 | Heating & Cooling
Gas valve opens and burner lights but the furnace blower does not start the blower will run in the on position. controlboard is a honeywell st9120c
Here is the specs for your board
http://customer.honeywell.com/techlit/pdf/PackedLit/69-0781.pdf
Check the wiring to be sure you're getting all the inputs and proper timer settings.
It could be bad. (sometimes the fan relay goes bad)
Oct 28, 2010 | Honeywell Fan Timer Board St9120c 2010
I am being told that I need to replace my furnace circuit board (Honeywell ST9120C 4016). I just replaced it 2 yrs. ago. Any ideas? If it needs to be replaced, where can I purchase it?
is it working properly if so then the ancer is no if yes remove it and take it to local apliance store and have them test it thay may have a used one cheep !!!!
Feb 10, 2010 | Honeywell Fan Timer Board St9120c 2010
Kitchen Ranges Logo
842 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
