Question about Polaroid a700 Digital Camera
I put new batteries in my camera. The lights come on, but the screen is blank.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
Why does my Samsung i85 digital Camera does turn not on even with a new charged battery
Sure the battery is charged? Can you operate the camera with just the adapter? If so, does the camera work then. If so the new battery is defective.
Sep 24, 2017 | Samsung i85 Digital Camera
My lcd screen is blank but the camera acts like it is taking a picture. Cannon PowerShot S3 IS
Had the same problem with my S3 is and couldnt find any help other than to junk it and buy another camera. WAY too expensive to repair (out of warranty)
I found a post and this worked for me...just fixed it about an hour ago. Mine would show a blank screen on the LCD nothing thru the view finder other than the menu screen. Found out the shutter was stuck and that seems to be a common issue with these cameras. This is how I fixed mine.
1. set the shutter speed to the longest setting you can. I put mine on the TV setting.
2. close the flash and set turn off all of the functions you can to conserve the batteries.
3. take a picture and within 5 seconds open the battery door. Then close it back and repeat. Your trying to interrupt the shutter reset process thereby "unsticking" the stuck shutter.
4. If this fails then try LIGHTLY tapping the camera against a piece of wood, again to unstick the shutter.
Sounds like a bad idea but considering I had tossed my camera in a drawer and already replaced it, I didnt really have much to lose. I was pleasantly suprised to see that after about 15 resets (steps 1-3) and a couple of light taps, the camera is working good as new again.
Good luck, hope it works out for you!
Jul 11, 2009 | Canon PowerShot S3 IS Digital Camera
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
DXG-506V LCD comes on Blank White Screen
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 03, 2008 | DXG Technology DXG-506V DV Digital...
Cannot see through the monitor screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 16, 2008 | Casio Exilim EX-S600 Digital Camera
Psp turns on but there is a blank screen
it probably froze try and remove battery. if that dont work turn it on and wait a second then hold the power switch in the off position but do not let go until it turns off that should completey restart it.
Jul 14, 2007 | Sony PlayStation Portable (PSP) Console
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Screen is blank
You tell me that you tried new batteries. Have you tried a set of NiMH batteries? They are the best for digital cameras. Please try a set, preferably ones rated 2200 or higher. If this doesn't help, the lens could be jammed. Hang onto the batteries though, because they are rechargeable and can be used in anything that takes AA batteries.
Apr 14, 2007 | Olympus FE-115 Digital Camera
Blank Screen
Camera is designed with one cirucit board to control most functions. The camera probably has a damaged component or dead CCD chip. There is no economical solution but replace the whole camera because the part is not available to replace it.
Mar 12, 2007 | Vivitar ViviCam 3500 Digital Camera
Polaroid a700 Digital Camera Logo
19 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
