Question about Robot Coupe MP550 Handheld Blender
Cant remove the drive frame on robot coupe 550
Robot coupe jucier machine need price quote
we do not quote any prices here . this is a repair help site
Dec 19, 2015 | Robot Coupe Blenders
Why doesn't drive shaft spin?
might be the start switch in the motor and or a capacitor. it should turn fairly freely by hand, if not it could be a bad bearing/bushing.
May 08, 2014 | Robot Coupe "R2 DICE - Combination Food...
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
May 28, 2013 | Robot Coupe MP450 Handheld Blender
ELECTRIC DIAGRAM ROBOT COUPE MP450
I need a wiring diagram too don' Robot Coupe have service info. on their products as expensive as they are it's a problem. Robot Coupe MP450 Turbo can't seem to find anywhere. Thanks
Jun 02, 2012 | Robot Coupe MP450 Handheld Blender
Need to know how to remove shaft and blade from lower bell assy as the blade is bent and bearing is bad excessive play in shaft
There is an exploded diagram here which should show how it dismantles
http://parts.robotcoupe.net/mp450.html
Not sure where you are geographically but hope that helps.
You can buy the bearings, I  was going to suggest that it wasn't worth repairing and then I checked the price of a new one!!!!  It is worth repairing I can't believe how expensive they are! Good Luck
Jan 12, 2011 | Robot Coupe MP450 Handheld Blender
Disassemble
we found the solution to the problem on your website.
Thank's for the tip.
Feb 15, 2010 | Robot Coupe MP450 Handheld Blender
Does any one know how to dismantle a blender mp 450 robot coupe?
4 screws are covered by caps in the handle area, everyone finds these but there are a further 4 screws found by removing the air vent grilles. The grilles are held in place along their shorter sides midway. Pop a fine screwdriver in at this point and the grille comes off.
Jun 03, 2009 | Robot Coupe MP450 Handheld Blender
Robot coupe mp 450
http://www.retrevo.com/support/Robot-Coupe-MP450Turbo-Food-Processors-manual/id/23109bh930/t/2/
Hope this helps you can download it by PDF
May 22, 2009 | Robot Coupe MP450 Handheld Blender
MP 450 TURBO
If you type in your model number on the internet information will come up on it for parts & other things. Hope this helps
May 04, 2009 | Robot Coupe MP450 Handheld Blender
Robot Coupe MP550 Handheld Blender Logo
44 people viewed this question
Top Robot Coupe Blenders Experts
Ruth summersides
ray gallant
Are you a Robot Coupe Blender Expert? Answer questions, earn points and help others
