There is no dial tone, unless it is on speaker phone. How do i solve this issue besides exchanging my phone?There is no dial tone, unless it is on speaker phone. How do i solve this issue besides exchanging my phone?
AnonymousSep 13, 2008
My GE portable phone has not dial tone, cannot make calls or receive calls on it, yet the battery is good. My son left it outside overnight and it had a bit of dew on it in the morning. What now?My GE portable phone has not dial tone, cannot make calls or receive calls on it, yet the battery is good. My son left it outside overnight and it had a bit of dew on it in the morning. What now?
had the same problem. maybe a power surge or tired chip. i tried reprograming the phones but no luck. i unplugged the base station then went through the setup...the cordless phones now work. hope this works for you.
You can't post conmments that contain an email address.
If you unplug the phone (both the telephone line & the power line) then plug it back in again it should start working again. Unfortunately it's not a permanent fix but it will get you through the day.
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
Here is a link to the GE website with manuals. I found 5922 EE1 and EE2. I wasn't able to find FE2, but I bet that one of the 5922 manuals will probably help...
I have had the same problem before and now again for the last week...I finally remembered what I did last time to solve it!
I put my "unavailable" Handset into the main cradle and left it there for a slow count of 20. That has reset the unavailable handset and returned the dial tone etc.
Dial tone is OK, but can't dial out • Make sure the tone/pulse setting is programmed correctly. TONE/PULSE DIALING 1. Make sure the phone is OFF (not in TALK mode). 2. Use the CID/VOL left (-) or right (+) arrow button to scroll to 1TONE or 2PULSE, or use the touch tone pad on the handset to enter the desired setting. For example, to choose TONE dialing, press the number 1 key. 1TONE is the default setting. 3. Press flash/program to store selection. You will hear a confirmation tone.
AC/DC Power not connecting, hence not charging at all. Dial tone is
also so low it cannot hear from very near.Hence the cordless handset is
useless since last 3-4 month. No support available for me. My Product
code is ES 27923GE2-B (GE 2.4 GHz)
TONE/PULSE DIALING To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Lisa,
If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model.
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
I need someone to chack my phone line to see what is wrong
MY PHONE HAS NO TONE AND IT DOSENT MAKE ANY CALLS OR TAKE ANY CALLS
HELP
