Question about Car Audio & Video
After holdind down the as button and turning the stereo on, safe comes up on the screen but doesnt allow me to enter my code?? just says safe all the time
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try leaving the radio on for an hour or two.
Posted on Aug 26, 2010
Radio stuck in safe mode, holding the PSCAN and RBDS buttons doesn't display the "1000" where I am able to enter the code.
first off is it the original stereo that came factory if it is try this solution:
1:turn ignition on but do not start
2: turn on stereo
3: do not touch anything else
4: wait 5-10 with stereo on and ignition on 10 min to be sure
5: after 10 min turn of ignition only remove key exit vehicle
6: set alarm
7: wait 10 more min
8 disarm alarm
9:put key back in ignition and set to on do not run
10: stereo should now work
Nov 14, 2016 | Audi Cars & Trucks
Car stereo not working,, could be in safe mode ?
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
May 09, 2017 | Vauxhall Cars & Trucks
I have a vauxhall vivaro and I have the code however i cant get it out of safe mode - i have tried holding down AS button for 3 seconds and switching the stereo off and then on etc and nothing has worked?...
Hiya,
I did this last week for a Vivaro that I have just bought.
This will defo get it out of safe mode and will get it working again If you have the code... Switch engine on with stereo off. Hold down AS button then turn the stereo on...safe mode should dissapear then press number one until the right digit is in the box and continue until the 4 digits are in. Then hold AS down then turn the stereo off again.
If you don't have the code contact the dealer for it usually £25 or buy the code online if you get the code number from the back of the stereo. Look for Grundig stereo codes or something like that online, there are loads on ebay.
Anyway
Good luck
Louise
May 29, 2009 | Car Audio & Video
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Audi tt stereo problem
Press and hold SCAN and RDS. 1000 will appear and you can enter your code using the station buttons 1-4 to set the digits.
Jan 31, 2009 | 2001 Audi TT
Unlock procedure for 1998 Audi A8 matshushita/ panasonic stereo
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. Use station buttons 1,2,3,and 4 to enter the code number from your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Jan 02, 2009 | 1998 Audi A4
Cant enter my car radiocode ???
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Nov 26, 2008 | 2001 Audi A4
97 VW Cabrio
If you have the Delta stereo (with the power/volume knob in the middle), you need to hold the "DX" and "FM1/2" buttons simultaneously. Hold them down for a few seconds, and SAFE will be replaced with numbers. Use the radio preset keys (1-4 I believe) to enter each number. When the code is successfully input, hold down the DX and FM1/2 buttons again, and the stereo will start to work.
If you mess up entering the code, you can try again. If you mess up a second time, you have to leave the stereo off and the key turned on in the ignition for an hour to allow you two more tries.
Oct 21, 2008 | 1997 Volkswagen Cabrio
Instructions to unlock stereo
THIS WAS POSTED ON THE AUDI TT CLUB WEB SITE.
Turn on the radio. The word "SAFE" appears on the display.
* Press the FM2 and RDS buttons simultaneously and hold them down until "1000" lights up in the display. Release buttons. Do not, under any circumstances, continue holding them down or press them once again. This would cause the radio to consider the number "1000" to be the input code number.
Use stations buttons 1 - 4 to enter the code number on your Radio Card.( THE RADIO CODE SHOULD BE WITH THE OWNERS MANUAL-??) Use button 1 to enter the first digit of the code number, button 2 to enter the second digit, and so on. Station buttons 5 and 6 cannot be used.
* Once the code is shown in the display, press the FM2 and RDS buttons again simultaneously and hold them down until the word "SAFE" appears on the display. Soon afterwards, a frequency will be displayed.
(If you do not have the "Radio Code", the Audi dealer, or someone, will have to pull the radio out to get the serial number off of the back.)
The radio can now be used again.
Aug 14, 2008 | 2004 Audi TT
Car Audio & Video Logo
12 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
