Question about Moen & One Handle Tub & Shower Faucet
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB &SHOWER FAUCET
    Problem Solver:
  • 19 Answers
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Posted on Aug 26, 2010
Can you adjust hot to cold ratio on moen single handle shower faucet
Pull off the handle and there are limiters located under it. They come set with not enough hot allowed, I have found. It is an anti scalding issue.
Sep 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Replaced trim ring and handle, now hot is cold ,cold is hot
Remove the handle and turn the stem of the cartridge 180 degrees then put your handle back on.
Apr 27, 2010 | Moen & One Handle Tub & Shower Faucet
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Have a moen tub faucet put in new o-rings and now it wont stay pushed in to turn off this is a older model that just pulls straight out then turns l/r for hot & cold
a possible problem,there is some thing else in there,take apart again and look in there and maybe flush it out before you put it back together
Feb 20, 2010 | Moen & One Handle Tub & Shower Faucet
I have a new moen single handle shower faucet that is only giving one temp of water (cold). Only if I have it on very slow will I feel hot water. Any idea how to fix
Did the hot water shut off get turned back on fully after the change? Is the hot water line kinked under the sink? Is the hot water shut off valve working?
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
1,373 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
