Question about Canon imageCLASS MF6530 All-In-One Printer
After replacing the tone, it does not copy.......at all!!
  • 1,110 Answers
By "does not copy at all" do you by chance mean the paper comes out blank?
If so there are some things to check. First remove the new toner that you just installed and make sure you pulled out the long seal tape that holds the toner in the toner box.
If that is ok, then take the old cartridge and shake it from side to side a few times and re-install the old one back into the copier. Any change? If so then your new toner is bad. If they are still blank with both cartridges then you may have broken the laser shutter. Inside the port where the toner goes is a small plastic arm that opens a shutter when the cartridge is installed. These little arms can break and when the do the shutter door does not open and it blocks the laser light from getting to the cartridge and this causes the blank sheets.
Look inside the port where the cartridge goes up towards the top and look for a closed off slot in the black plastic looking box. The slot is about 1/4 high and runs from one side to the other. When found you can manually lift up the gate that has this slot closed off. Once opened you can take a small scrap of cardboard or folded up paper and block it open from the far right side. Do this if neccessary and re try the copies. If they come out fine then you will have found the cause. I have a few customers with this solution still working on their copiers for the last year.
Good Luck and Thank You for using Fixya.
Posted on Aug 26, 2010
Repalce tone message appeared and i replaced the tone but it still display the same message why?
You have to just reset the gear of the cartridge of the Printer.
you have to install the gear facing downwards & your message will be removed.
Aug 31, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
How can we avoid moire or screen clash when taking copies of originals containing half tones photos?
enter service mode(*28*>copier>adjust>ae>) enter value 1 there touch ok and press reset twice check half tone copy and adjust from service mode accordingly.
Jan 01, 2011 | Canon imageRUNNER 400S Copier
Samsung E2550 phone has 4 preset message alert tones. Is it possible to add a downloaded one since there does not appear any option to do so?
yes,there is obviously an option to do so.u need only to copy a tone in phone memory then select it and click options then u'll have lot of options to set it as-ringtone,msg tone,alert tone ,alarm tone etc.
Nov 18, 2010 | Samsung Lands Phones
Suddenly, there was a high tone pitch when I make copies...
TRY CLEANING AND LUBING THE SCANNER RAIL WITH A LIGHT GREASE.
Apr 28, 2010 | Sharp AR-M205 Copier
I-mate smartphone
you cant set regular songs (mp3) as ring tones. only ring tone files (m4a,wav) as ring tones. they are shortened versions. try Http://www.nextpimp.com
for some good ring tones that are totally free
Jun 16, 2008 | i-mate Smartflip Smartphone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
Redish tone
This is because your printer heads needs to be cleaned or replaced! or either some particular colour is empty!
Nov 20, 2007 | Epson Stylus RX500 All-In-One InkJet...
Copying downloaded music
on most phones u can select the tone and either click copy or move and it should ask copy or move to phone mem.or card and just select phone memory and it should work
Oct 15, 2007 | LG VX8300 Cellular Phone
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Canon imageCLASS  MF6530 All-In-One Printer Logo
old marine
old marine
