Question about Refrigerators
Is there a reset switch on the fridge to use after the fridge has been unplugged for a long period of time? Crosley
    Champion:
  • 245 Answers
No, You might want to check the plug. The timer could also be stuck in defrost. Find the defrost timer and manually spin it. Rate me. Thanks
Posted on Aug 26, 2010
CROSLEY FRIDGE/FREZER COMPRESSOR WORKS WILL NOT COOL FAN WILL NOT RUN
Typically, that would be caused by failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
There should be an electrical schematic diagram attached to the back of the unit. You may be able to use that to identify the faulty part. Don't be surprised if the replacement board costs alot more than it's size and simplicity might indicate.
Oct 09, 2014 | Crosley Refrigerators
Error code PAU, what it means
The washer is stuck in "pause" mode. You can try pressing the Start/Cancel button to see if that clears it. If not, try unplugging the washer for about 10 minutes to force a reset.
If still no go, suspect problem with door latch/striker switch or failure of a cheap chinese control board. In fact, failure-prone chinese control boards are at the heart of virtually all premature failures of modern appliances. They usually only last just long enough to span the warranty period.
Sep 29, 2014 | Crosley Washing Machines
Crosley gas dryer panel lights blinking will not turn on
Hello - I understand the lights are blinking; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker off. Wait approximately two minutes and turn on the dryer. Select a normal cycle and if it is ineffective contact a professional to move forward accurately. The unit may possibly have a defective cord or wiring, control board or door switch.
Oct 14, 2012 | Crosley CDG6000 Gas Dryer
I changed the water filter in my Whirlpool refrigerator, model #EDVHEXVQ01. I then tried to reset the filter light, but it did not work. Should I do something different to reset it or did I do something...
Hi
I guess you changed the filter with the fridge plugged in, you need to switch off and unplug the fridge, switch off the water. Then switch on the fridge and bleed the water line for 5 second intervals every 5 seconds for 1 to 2 minutes.
That should solve the problem
Regards
Gordon
Apr 20, 2011 | Whirlpool Refrigerators
The glue gun switched off will nor switch back on is there a reset button or switch
some guns have an auto shut off after the gun has not been used for a certain period of time. if you cant find a reset button, just unplug and replug it
Apr 12, 2011 | Dremel 120001 Glue Gun Kit
Leaks water inside fridge when door is opened. Also leaks water under fridge when closed for long periods of time.
if this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Sep 01, 2010 | Crosley Refrigerators
Crosley fridge will not stop running?
Check the seal (gasket) around the door. If the seal is not sealing properly the compressor has to keep running all the time.
Aug 07, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
