Question about Woods Upright Freezer MU07W
I have a Woods refrigerator that is all fridge, no freezer compartment. Model # RFA17NAC. s/n 07605297JG. It is leaking water on the inside of the fridge and collects on the fridge floor. No manual came with the fridge so not sure if the defrost tubing is plugged or how to change it. Do you have a repair manual you can send to me? Or explain how to fix this. Thanks Linda Fader
Hi Linda. We have the identical model of Woods all-fridge and
experienced this problem several times over the course of several
months. Hopefully this is still timely.
The short answer is that the clear flexible-plastic drain tube that runs
from the inside rear of the fridge down to the catch tray (underneath
the cabinet, next to the floor, behind the kick-plate) is sufficiently
plugged (with some kind of gunk, probably from a spill inside the
fridge) to cause a back-up. I suppose the inner diameter of the tube is
maybe 3/16" so it can easily get clogged. Consequently, the water runs
down the inside back of the fridge & eventually ends up in the
depressions below the crispers. In our case, after those depressions
filled (and I hadn\'t noticed), the water would run out onto the floor.
Initially, I used a fine wire to poke some of the gunk out of the tube
but I didn\'t get it all out. Just enuff to let some of the water get
thru, but the tube would plug up again. After a few repeats of the
problem, separated by a month or 2 each time, I decided a more "drastic"
tube cleaning was required.
I suppose a good strong compressed air blast might clear the tube
completely, but I didn\'t have that available so I had to use a
semi-flexible wire & sorta gunk out the tube. It\'s been about 1.5
yrs. since that more thorough tube cleaning & the problem hasn\'t
come back, so I think the tube got plugged from a spill in the fridge
(which thankfully hasn\'t re-occurred... yet).
BTW, I don\'t have the manual either, but the lower part of the tubing is
accessible from behind the fridge. I didn\'t pull it completely out
(which might have disconnected it from its fitting), I simply reamed it
out while it was in-place.
Hope this has been of some help to you.
Norm.
Posted on Nov 25, 2010
  • KAREN PORENCHUK Aug 05, 2013
    A small amount of drano followed by boiled or hot water work while inserting a stiff wire to unclog the grey gunk. Let sit 15 minutes and flush out. Clan drip tray after this.
  • Mchel
    Mchel Dec 29, 2014
    Thanks , this also fix my problem.
Hi, I had the same problem where my woods fridge was leaking water ever 10 days or so. I wasn\'t sure where the drain was, so I looked Up the manual online to find it. I also have a large fish tank, and I already have this wire tool with a brush on one and a stiff wire end that is about 3 feet long and flexible, i used that to push the gunk out of the drain tube. I also used some Javax to disinfect and clean the tube out. The tool from the pet store was $2. And worked awesome! In total it took me about an hour to pull out my fridge, take the drawers out, take the inside cover off, clean out the plug, and totally clean my fridge inside, out and under. And put it all back together. Yes it was gross, but I felt empowered to fix it myself :) p.s. I disinfected my pet store tool to use again on my fish tank.. Hope this helps someone
Posted on Mar 21, 2014
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Woods Upright Freezer MU07W Logo
3,807 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
