Question about Quasar HQ2051TH Air Conditioner
The air that it throws is not that cold, i wanted to know which part do i have to change?
  • 139 Answers
The best cure is to take the unit outside use your garden hose to clean the coils ..remove the front cover/ cover switches with tape ..spray coils on both sides real good to remove dirt ..let the unit dry good ..clean filter and it should work like new again..let me know ..good luck/joe/
Posted on Aug 26, 2010
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
MY HEATER BLOW OUT COLD AIR ON MY 19999 CHEVY VENTURE
Hello, You need to open the two breeder valves and make sheer ur getting coolint throw ur hoses. And make sheer you have no air throw your lines.
Jan 27, 2014 | 1999 Chevrolet Venture
My car heater is not working its only throwing out cold air
You may have a broken blend door or control, blend moor is very hard to fix.
Dec 30, 2013 | 2004 Chevrolet Aveo
AC is not throwing cold air anymore?
the unit must've run out of gas.You need to get a proffessional to get it re-gased.And ask him to locate any gas leak along the copper pipes and connections.
Dec 27, 2013 | Heating & Cooling
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
ON THE THERMOSTAT THE DIAL HAS 1-9 WHICH NUMBER DO I PUT IT ON FOR IT TO THROW COOL AIR
Only guesssing try either way and wait tell the unit puts out cold air but it shuld put it out if you place it on 4-5 .. let me know
Jul 23, 2011 | Goldstar WG5000 Air Conditioner
My heat is not working. Its throwing out very cold air now. It happen before and i replace thermostat and blew air threw heater core. I blew air threw heater core the other day now its throwing out real...
It sounds like your heater core is stopped up, or be sure your coolant is flowing, and picking up heat from your engine...Thermostat, water pump, etc.
Jan 30, 2009 | 2000 Chevrolet Blazer
Air Conditioner blows very hot air
ASE mechanic here:
sounds like a mode door is stuck causing the air flow to go across the heater core only and not the evaporator. try activating the hot to cold functions to may be un stick the doors. if no changes then try a computer scanner, these new cars can have HVAC control codes and be accessed with a scanner, telling you the problem. if no access to that a good European shop is the next best thing. They might be cheaper than a Porsche dealer.
Jan 26, 2009 | 1998 Porsche Boxster
My ac turns on but it only throws hot air it used to throw it cold a few days ago, whats the problem?
Adding a can of freon is not the solution, a system that has too much freon will not work right and there is a chance that you will damage the compressor.
There are low pressure and high pressure switches at work when the system is operating.
You might have a bad switch, leaves or other matter blocking the front condenssor.
Is the system actually full?
It's best to give this problem to a certified A/C mechanic.
Oct 01, 2008 | 2002 Jeep Grand Cherokee
Quasar HQ2051TH Air Conditioner Logo
Top Quasar Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Quasar Heating and Cooling Expert? Answer questions, earn points and help others
