Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Wont turn on
My tv just wont turn on. didnt have any problems with it, then all of a sudden went to turn it on and there is no response. did the basic troubleshooting, power is coming to the tv.
I have a RCA 52 inch HDTV ready monitor D52W20. when I push the power button the tv power light comes on green then goes off. it does this 3 times and then stays off. On a rare occasion it will come on as if nothing is wrong. But if I turn it off again it will not come back on. I checked the fuse next to where the power cord meets the board and it was not blown.
  • 4 more comments
  • Anonymous May 21, 2008
    I have the exact same problem as Robnhar i push the button the light comes on then out then on the picture never comes on then the light will go off if i mess with it long enough it will turn on sometimes it will stay on all day sometimes it will shut off in the middle of a show and not come back on again
  • Bigbee501 May 21, 2008
    Very same problem, began with intermittent "blips" usually first thing in the morning, small sound interruption, progressing to momentary picture interruption, finally shutting down with an audilble "sput" sound. It may try 3 times to restart, then gives up. May work at a later time as if there is nothing wrong.
  • acrowley39 Sep 23, 2008
    tv won't turn on
  • dominic swin Sep 23, 2008
    i have the same problem...i also change the power supply bord...what can i do next??
  • mslilbit Feb 25, 2009
    I'm having the same problem. Turned it off the other morning and when I went to turn on later that day the green light comes on then goes off then comes on again and goes off again but the tv never shows a picture.
  • Anonymous Feb 27, 2009
    Mine does this also. It won't even come on occasionally anymore.
  • RCA Master
  • 8,617 Answers
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
Posted on May 06, 2008
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: RCA D52W20 52 in. Rear
most likely the vertical IV has faiked which is causing the tubes to shutdown, You can get a replacement vertical IC for your model at the following link. If your not sure which one you need leave them a email with the model number and the symptom, they respond quickly.
http://servicemanuals.vstore.ca/
Posted on Jan 31, 2009
supertech6
  • 513 Answers
SOURCE: Problems with RCA D52W20 52 in. Rear Projection
Do you mean replace the front plastic screen. Are you sure you want to? This screen is $500+ if you can still get one. A tech may have to come in and remove the bezel to insert the screen (some remove fairly easy...) You can get a pretty nice LCD TV for $700.
Posted on Mar 31, 2010
Problems can be solved for free
This website is not a scam their is thousands of people every day who recieve Free Help from some of the Best Electronic Techician around the world.
You didnt said what the Problem was with your TV?
Jun 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Wii froze and wont Turn off after playing game
dead disc? or disc reader? also why woulf turning the tv off help? did the wii overheat? or anything strange?
Apr 05, 2010 | Nintendo Wii Console
My ps3 shows nothing but background waves, wont load main page
unplug PS3. Wait 10 minutes and turn on.
do the same with the power supply.
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Apr 11, 2009 | Dynex DX-LCD37 TV
1996 Sony 32" Trinitron - Suddenly lost picture and sound
The most common problem with TV was the failure of the Horizontal Output Transistor, this will also damage 2 transistors in the power supply and a resistor in the power supply also. (From memory): Horizontal Output location # Q501, 2 power supply transistors Locations Q601, Q602, and resistor Location R607. Also solder the Horizontal drive transformer, you can find it by following the circuit board from the base of the Horizontal output. Some models used an IC instead of the 2 transistors in the powersupply, it will have six legs and check like 2 transistors. Good Luck.
Jun 04, 2007 | Sony KV-32S26 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
635 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
