We have a Carver fanmaster warm air heater in a caravan and it blowing out cold air, we cannot get any warm air from it. In the Lunar manual it says press the restart button but I cannot locate it. Do you have any ideas please. Many thanks Jenny
  • stephen prosser Jul 16, 2011
    hi i got a caver fanmaster when you turn it on it heats up but wont blow so i got it out from behind the fire i tested it it seems to have power going to it
    so i got the fan motor out tried it on a car battery and it worked on top of the motor there is a small pcb board with two wires coming out the top of the board they are to short to go any where
    is it one wire which has snap
    can anyone help please
  • 3 Answers
Hello, i have a luner eclipse with the same prob, go into the cubourd behind the heater as you look down the left side there is a button for reset press forward, this will reset electric. you should now get heat.... im looking for a copy of fridge manual. as i dont have any paper work for my van. richardcharles787@gmail.com
Posted on Feb 01, 2011
Hi I have the same problem with my Carver 2000 fanmaster
did you find out what the problem was
Posted on Jan 23, 2011
Hi i had the same problem and fixed it by replacing the thermal fuse which is inside its a soldering job that is quite easy to do, if you stay near glasgow a could help you,robert
Posted on May 19, 2013
My 1999 caravan is blowing cold air
Check the water Coolant level in the coolant reservoir and also remove the radiator cap, which tends not to be on the radiator any more and check it is full. Also burp the system by removing air licks buy sqeezing the radiator hoses when the system is hot. Remove the radiator cap before you do this. You also need to check the thermostat for correct operation as it might be stuck closed. Remove it, put it in a pot of warm water put it on the stove and you should see it open before it comes to a simmer.
Nov 18, 2015 | Cars & Trucks
Carver fanmaster 3000s heater
Element burnt out or open thermister
Dec 07, 2013 | Audio Players & Recorders
Heater isnt blowing warm air in 2003 grand caravan
Assuming the radiator is full of coolant, you are describing a faulty thermostat. The thermostat is closed when the engine is cold to restrict coolant flow until it warms up.
Feb 01, 2013 | 2003 Dodge Caravan
Carver 5500 turbo fanmaster keeps blowning the
its sounds like you have a sort some where, if you have a compressor , or the heater element could be bad? slide heater out to see if there is a burnt wire
Apr 11, 2010 | Heating & Cooling
Hi there. I need a replacement Fanmaster slide switch for a Carver Space Heater 4000. Any ideas how/where I could get one or repair it? Thanks.
Look on Ebay. There is a guy who fully repairs these.
User name lloydwjones
or search Repair to Carver Caravan Space Heater Control Unit
Mar 15, 2010 | Heating & Cooling
Heater slow to work
this sounds normal in very cold conditions! The air is never hot when you first start the car in any car, until the engine warms up, then the heater air will also warm. You could check your anti-freeze level for the first thing. If you don't have enough anti-freeze, it won't run through your heater to give you the proper heat
Dec 11, 2009 | 2000 Dodge Caravan
Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Jan 18, 2009 | 2001 Dodge Grand Caravan
Heating & Cooling Logo
1,776 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
