Question about Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
Need manual for DeWalt 6000 generator - Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
    Scholar:
  • 97 Answers
Here is the link for the manual to download hope this helps
HERE
Posted on Aug 31, 2010
3 Suggested Answers
  • 905 Answers
SOURCE: dewalt 6000 generator won't accelerate when using
Okay, I assume that you are referring the economy mode / idle control feature of the generator.
When this is turned on, the engine should run at a slower speed, until a load is detected, then the engine should speed up very quickly. Turning this feature off should result in the engine speeding up quickly as well.
Normally, this is done using a solenoid that is connected to the governor arm. When idle control is requested (run slower), the solenoid engages, and pulls the governor arm in a way so that the throttle is closed. When idle control is disabled (or load detected), then the solenoid sits unpowered, and governor arm is allowed to react normally with its spring tension, and increase engine speed.
Sometimes, a bunch of grit can accumulate in the solenoid body / assembly. Remove the assembly from governor arm, and the generator should run at full speed. After cleaning, replace solenoid, and test. if stil failing, make sure solenoid works by applying 12 volts (usually) to it, to see if it kicks. If it does, look for break in wiring, or at control board.
Good luck.
Posted on Jan 04, 2010
Testimonial: "Thank you. After attempting what you suggested, we discovered the governor arm was bent just enough to not let the idle control do its job. rus"
  • 6 Answers
SOURCE: dewalt generator 6000
have your windings checked good luck
Posted on Jan 19, 2009
Dewalt gasoline generator ..rope does not pull
Try taking the spark plug out and see if you can turn it over.
Feb 16, 2015 | Dewalt Generator. 6000 Watt Portable...
Generator does not start
The float bowl their is a drain bolt, take it out check for gas.
Aug 23, 2012 | Dewalt Generator. 6000 Watt Portable...
NO OUTLET POWER
There can be several causes for this symptom. Does the outlet have a breaker or "switch" that is tripped? If this is a GFI (ground fault circuit interrupter) outlet, first disconnect any cord or equipment plugged into the outlet, then press the "reset" button in the middle of the receptacle. The GFI's should not/will not reset with anything plugged in. (If they are working correctly.) More specific information needed if this does not take care of the problem. There are numerous other things which could be causing this problem, loose conections, bad generator, broken or damaged wires on the electrical system, inverter problems, etc. Refer to your owners manual if at all possible, take a look here at this link if you don't have a copy.<<< http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DG6000&selectedType=6326# >>>>
Feb 22, 2012 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Where can I find a schematic for a dewalt dg6000 generator
Here is a 4.3 MB pdf manual for Dewalt generators: 2900 4300 6000 7000
http://waterheatertimer.org/pdf/Dewalt-2900-4300-6000-7000.pdf
Dewalt has service centers and parts sales, you'd think they'd be eager to post manuals on their webiste. Service centers are probably only place to get parts.
Oct 11, 2010 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
I need a exploded view of parts for a DG6000E dewalt generator
Here is an exact link to the parts and exploded diagram you are looking for! Hope it helps!
DG6000E DeWALT Parts Diagram
May 21, 2010 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
Dewalt generator 6000
Jan 17, 2009 | Electrical Supplies
Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator Logo
630 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
